chli1976 Profi-Schrauber
19-02-2019, 23:22 Subject: BMW E61 530xd, year 2006, ABS ring |
Does anyone know where I can find an ABS ring for a 530xD E61? I need one for the front right side.
I only found parts that fit the E46. Does anyone know if they are the same? I've already searched online, but couldn't find anything.
VCDS
Translated on 16-07-2026, 11:55.
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
dieselschrauber likes this. |
20-02-2019, 17:46 Subject: Sensor ring |
Hi there,
It's clear that you won't find anything, because the magnetic segments are integrated into the bearing shield of the wheel bearing.
It's been like that since the E39. You probably need to replace the wheel bearing.
"Stick with SKF or FAG; I've had signal problems with other brands after replacing the wheel bearings."
Part number: 31226783913
Applicable to the following vehicles:
BMW 3 Series Sedan (E90) (Production year 03.2005 - 10.2011, 163 - 306 hp, Gasoline, Diesel)
BMW 3 Series Coupe (E92) (manufactured from March 2006 to December 2013, 177 - 306 hp, gasoline/diesel).
BMW 3 Series Touring (E91) (manufactured from August 2005 to June 2012, 163 - 326 horsepower, gasoline, diesel).
BMW 5 Sedan (E60) (Production year 09/2004 - 03/2010, 197 - 272 HP, Gasoline, Diesel)
BMW 5 Series Touring (E61) (Production year 02.2005 - 12.2010, 197 - 272 HP, Gasoline, Diesel)
BMW X3 (E83) (manufactured from November 2003 to December 2011, 136 - 286 horsepower, gasoline, diesel).
BMW X5 (E53) (manufactured from May 2000 to December 2006, 184 - 360 horsepower, gasoline, diesel).
Mpire
| Description: |
| File size: |
656.06 KB |
| Viewed: |
696 times |
Translated on 16-07-2026, 11:58.
Profile PM Garage |
21-02-2019, 9:37 Subject: BMW E61 530xd, year 2006, ABS ring |
You're wrong; it's on the joint. It might be at the back, but I haven't looked. However, I need the ring for the front. I mentioned that in my first post.
VCDS
Translated on 16-07-2026, 12:01.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
22-02-2019, 10:01 Subject: BMW E61 530xd, year 2006, ABS ring |
Here's how you can identify the wheel bearing for the front:
Profile PM Garage |
22-02-2019, 17:08 Subject: BMW E61 530xd, year 2006, ABS ring |
"Mine has an ABS ring on the drive shaft joint, and the sensor was also rubbing against it because the ring was rusted. But never mind, I've already fixed it. If I get it up on the lift again, I'll take a picture."
VCDS
Translated on 16-07-2026, 12:02.
