Replace Car Battery Without Losing Data
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vag-driver
Post03-03-2019, 13:32    Subject: Replace Car Battery Without Losing Data Quote
What is the best way to replace a car battery without risking losing settings, such as those of the radio?
"For example, I'm familiar with the CTEK MXS 7 or 10, which offer such a function, but I'm looking for a more affordable solution. Dealing with three batteries is also not an option."
Andreas
Translated on 04-08-2026, 6:49.
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post03-03-2019, 16:31    Subject: Replace Car Battery Without Losing Data Quote
I've always done that with a second vehicle so far.
Simply connect it to the jump start terminals in the engine compartment and replace the car battery.
WARNING! The exposed positive terminal on the vehicle side is live and carries electricity; protect against short circuits. I always wear a mechanic's glove over it, and nothing can happen.
If the vehicle has a Battery Management System (BMS), please remember to enter the new battery type – if different – and the "new" serial number into the coding. Changing just one digit of the previous serial number is sufficient.
The new battery should be fully charged before installation; so far, none of the ones I've bought have been completely full, only about 80%.
The state during recoding is important for the BEM reference, so please load it completely.
Regards, Mpire.
Translated on 04-08-2026, 6:51.
vag-driver
Post03-03-2019, 17:41    Subject: Replace Car Battery Without Losing Data Quote
However, these are not installed in every vehicle. If none are present, you need to connect to the positive terminal.
Andreas
Translated on 04-08-2026, 6:52.
Karma: +583 / -0   Thank you, like it!
Post03-03-2019, 21:29    Subject: Replace Car Battery Without Losing Data Quote
Hi!
I have a small device for that; it contains a battery, similar to a small motorcycle battery.
It will then be connected to the OBD socket with a cable.
I don't have vehicles that are quite so state-of-the-art and technologically advanced.
So far, this has worked well with my relatively simple cars.
Translated on 04-08-2026, 6:53.
vag-driver
Post04-03-2019, 8:46    Subject: Replace Car Battery Without Losing Data Quote
So far, this has worked well with my rather simple cars.
It's not about super modern cars, but rather my wife's 1997 Polo in this case. Specifically, the problem is with the Alpine radio, which immediately loses all its settings. And it's no fun trying to restore the DAB station list.
Andreas
Translated on 04-08-2026, 6:54.
Karma: +1090 / -0   Thank you, like it!
Post04-03-2019, 11:44    Subject: Replace Car Battery Without Losing Data Quote
This car has a constant power supply at the cigarette lighter socket – if it even has one. Basic models of that era often had this feature omitted. What would normally be an annoyance, such as for forgotten heated seat cushions, is actually quite advantageous in this case. The cigarette lighter provides enough power to maintain the memory (the outer part is negative, and the contact in the middle is positive). A power supply with approximately 12 volts is sufficient. I used one that was previously used to power (CB) radios. If you leave the ignition off and also turn off the interior light, a small AC adapter with approximately 12 volts should be enough.
The warning about the positive terminal on the battery still being under voltage has already been mentioned. With the suggested gloves, it should work; a Velcro strap can be used to secure them for extra safety. For this car, nothing needs to be reset. If the replacement is done without interruption, the car won't even notice the new battery.
Translated on 04-08-2026, 6:55.
vag-driver
Post04-03-2019, 12:31    Subject: Replace Car Battery Without Losing Data Quote
Hutfahrer wrote:
This car has power permanently available at the cigarette lighter socket, if it even has one.
He has.
Hutfahrer wrote:
If it's done without interruption, the car won't notice anything about the new battery at all.
That's clear.
I think the solution of supplying power to new vehicles via the OBD port is very good, because they will definitely detect that the voltage was interrupted there.
Andreas
Translated on 04-08-2026, 6:57.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Zündanlassschalter beim Golf3 wechseln Troubleshooting & Guides
No new posts Domlager wechseln am Golf 4 ohne Federbeinausbau? Transmission, Chassis, Body & Interior
No new posts Replacing front wheel bearings without removing the struts Transmission, Chassis, Body & Interior
No new posts Zahnriemen wechseln ohne Diagnose Gerät, geht das? Diesel Engine Technology
No new posts Autobatterie instandsetzbar? Diesel Engine Technology
