P244B Diesel Particulate Filter Differential Pressure (Solution)
Post09-03-2019, 15:51    Subject: P244B Diesel Particulate Filter Differential Pressure Quote
The error code P244B, "Diesel Particulate Filter, Differential Pressure Too High Bank 1," occurs when the diesel particulate filter on cylinder bank 1 of an engine is clogged.
The cause can be excessive soot buildup, which is often caused by excessive short-distance driving or malfunctions in the exhaust gas recirculation system or the temperature sensors on the DPF (diesel particulate filter) or engine.
Excessive oil consumption or a faulty turbocharger can also clog the diesel particulate filter due to the excessive amount of engine oil being burned.
Using the wrong type of engine oil can produce more ash during combustion, so it's important to adhere to the manufacturer's specifications.
Is the engine okay? The problem might be caused by ash that remains in the DPF after regeneration. This ash accumulates with each regeneration cycle and cannot be burned further, causing the DPF to gradually fill up. To be expected and checked approximately after 250,000 km of mileage.
Sure, I'd be happy to help with that. Please provide the text you would like me to translate from German to English.
Ratings - P244B Diesel Particulate Filter Differential Pressure
No new posts P244B - Diesel Particulate Filter - Differential Pressure... General Tips
No new posts Error code P1351 General Tips
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Important: DPF Back Pressure Normal Values Diesel Engine Technology
No new posts Differential pressure DPF vs. exhaust backpressure (and S... Diesel Engine Technology
No new posts DPF differential pressure slightly high Diesel Engine Technology
No new posts Differential Pressure & Backpressure: 3.0 TDI Comparison Diesel Engine Technology
