Hello everyone,
I wanted to check the switching point of my clutch pedal sensor on the CFGB today using VCDS, but I couldn't find it in the measuring values of the engine control unit. According to the wiring diagram, it should be sensor G476.
Has anyone ever found this before, and if so, under what name or designation?
Thank you & best regards.
pretzel man Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 27-08-2026, 15:36.
