Component protection active since the control unit was replaced
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Lochhaas123
Post16-06-2019, 21:18    Subject: Component protection active since the control unit was replaced Quote
"Good day, after a long search, I have found out why the automatic lights and the entire electrical system of my Seat Toledo are malfunctioning intermittently. It turns out that water is leaking from the windshield washer system into the body control module. I have now replaced the defective pins on the connector of the control module and installed a used control module, and adjusted the coding. Now, here's my problem: a component protection feature has been activated in all the other control modules. How do I remove this?" Or can this only be done by a Seat dealer?
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: DRV 18.9.0.2
Data as of: 20181017 DS296.0
Vehicle Identification Number: VSSZZZNHZG1008320
License plate: VB RL
Mileage: 58574 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: NH-SK25 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 55 5F
Vehicle Identification Number: VSSZZZNHZG1008320 Mileage: 58,574 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
10-Parking Assist 2 -- Status: OK 0000
15-Airbag -- Status: Error 0010.
17-Terminal block module -- Status: Error 0010.
19-Diagnostic interface -- Status: Error 0010.
44-Steering Assist -- Status: OK 0000
55-Beam angle adjustment. -- Status: not logged in 0001
5F-Information Selection. I -- Status: Error 0010
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CXMA) Label file: . DRV\04L-907-309-V1.clb
Part number SW: 04L 906 021 EG, HW: 04L 907 309 E.
Component: R4 1.6L EDC H22 1746
Revision: 86H22---
Encoding: 01110032032401090000
Operating number: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI01104L906021EG 001005
ROD: EV_ECM16TDI01104L906021EG_001.rod
VCID: 6ED7B786B1DF463A37-803A
No error codes found.
Readiness: 0 0 0 0 1
Address 03: Brake Electronics (J104)
Label file: Route not found!
Part number SW: 6R0 614 517 BQ. Part number HW: 6R0 614 517 BQ.
Component: EBC 460 ESP H52 0001
Serial number: A00UC1X
Encoding: 43F84876897E00DBC226122C91220079170900C1
Operating number: WSC 73430 031 00063
ASAM Dataset: EV_Brake1ESCEBC460PQ26L 003014
ROD: EV_Brake1ESCEBC460PQ26L_003.rod
VCID: 0301F6328A5D5B52C8-8056
Address 08: Climate Control/Heating (J255) Label file:| DRV\6C0-907-044.clb
Part number SW: 6P0 907 044 A HW: 6P0 907 044 A
Component: Climatronic H01 0201
Serial number: 1506141A-0174
Encoding: 011000001011000201
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26.rod
VCID: 2F696A8276550F327C-807A
Address 09: Central Electronics (J519) Label file:| 6C0-937-089-V1.clb
Part number SW: 6C0 937 089 D, HW: 6C0 937 089.
Component: BCM PQ26 Hi4R H08 0094
Serial number: 001378064933
Encoding: 0800085042150AFB43804000402F070800015900530A350000000000000000
Operating number: WSC 12345 123 12345
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 316D6CFA606119C26A-8064
Rain and light sensor:
Subsystem 1 - Part number SW: 5Q0 955 547 A HW: 5Q0 955 547 A Label file: DRV\5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M06D22H18M53S15
Encoding: 00185E
Driver's side door control unit:
Subsystem 2 - Part number SW: 6V1 959 801 B HW: 6V1 959 801 B
Part number: FHSG DRV 007 0001.
Serial number: 00000000000001599797
Encoding: 011200
Humidity sensor: internal:
6 error codes found:
8202 - Left daytime running light lamp.
B121D 15 [009] - Interruption/short circuit after the positive terminal.
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 3
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:08:22
8458 - Lamp for daytime running lights, right side.
B121E 15 [009] - Overvoltage/Short circuit after positive terminal.
Error priority: 2
Error frequency: 3
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:08:22
9738 - Left side marker lamp.
B12E8 15 [009] - Interruption/short circuit after positive terminal.
Error priority: 2
Error frequency: 2
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:08:53
9994 - Lamp for right-hand side marker light.
B12E9 15 [009] - Interruption/short circuit after positive terminal.
Error priority: 2
Error frequency: 2
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:08:53
12307 - License plate light.
B12CA 01 [009] - Electrical fault.
Error priority: 2
Error frequency: 2
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:08:53
15360512 - Component protection active.
U1101 00 [009] - -
Error priority: 4
Error frequency: 1
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:08:13
Address 10: Parking Assist 2 (J791) Label file:| DRV\5Q0-919-283.clb
Part number SW: 5Q0 919 283 D, HW: 5Q0 919 283.
Part: PARKING ASSIST 3K H10 0048
Revision: -------- Serial Number: 39291516108427
Encoding: 0001050001
Operating number: WSC 73430 790 00000
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_SK25.rod
VCID: 3A7F4BD6BD17DA9ADB-806E
Address 15: Airbag (J234) Label file:| 6C0-959-655.clb
Part number SW: 6C0 959 655 G, HW: 6C0 959 655 G.
Part number: VW20Airbag807 001 0360
Revision: -------- Serial Number: 003RK0005HWI
Encoding: 88CCC00000800000540000C8002800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 377952E28E05C7F224-8062
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: ----------- HW: 442 151 906 15
Component: SideSensor_Df, Part Number: 1CA 0148.
Serial number: 3497A009F1B6A755831S
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side:
Subsystem 2 - Part number: SW: ----------- HW: 442 152 206 15
Part: SideSensor_Pf 1CA 0148
Serial number: 3507A00C51ACFCF3744$
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side):
Subsystem 3 - Part number: SW: ----------- HW: 442 151 906 15
Part: SideSensor_Dr 1CA 0148
Serial number: 3517A00C91AC53B0A1DR
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side:
Subsystem 4 - Part number: SW: ----------- HW: 442 152 206 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C51ACFCF3531Z
Encoding: 2D2D2D
"1 error found:"
U1101 00 [137] - -
[New feature!] Extended UDS error code information is only supported by current hardware generations.
Warning light ON - confirmed - checked since last reset.
Error priority: 2
Error frequency: 1
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:10:54
Address 17: Terminal block insert (J285) icon_neutral.gif Label file: DRV\5K0-920-xxx-17.clb-SRI3
Part number SW: 6JA 920 741 G, HW: 6JA 920 741 G.
Part: COMBINATION INSTRUMENT 205 1421
Encoding: 072404002980000801086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 3F893AC2A635FFB2EC-806A
"1 error found:"
U1101 00 [009] - -
Error priority: 4
Error frequency: 1
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:02:48
Address 19: Diagnostic interface (J533) Label file:| DRV\6C0-909-901-V1.clb
Part number SW: 6C0 909 901 A, HW: 6C0 937 089.
Part: GW MQB A0 H08 0094
Revision: -------- Serial Number: 001378064933
Encoding: 030000044F0A590071000000000000010001010000000000000000000000
Operating number: WSC 00788 648 00255
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_SK25.rod
VCID: 26478FA659AF4E7A8F-8072
Battery monitoring control unit:
Subsystem 1 - Part number SW: 6C0 915 181, HW: 6C0 915 181.
Part number: J367-BDM H08 0223.
Serial number: 52154724574351165837
4 error codes found:
66304 - Data bus.
U1124 00 [009] - Excessive build-up detected.
Error priority: 2
Error frequency: 3
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:07:28
Supply voltage, terminal 30: 12.1 V.
Terminal 15: one.
67072 - Local data bus.
U1125 00 [009] - Multiple occupancy detected.
Error priority: 2
Error frequency: 2
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:07:28
Terminal 15: one.
U1101 00 [009] - -
Error priority: 4
Error frequency: 1
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:07:28
Terminal 15: one.
15360768 - Component protection active.
U1101 00 [009] - -
Error priority: 4
Error frequency: 1
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:07:28
Terminal 15: one.
Address 44: Steering Assist (J792) Label file:| DRV\6Rx-909-144-V2.clb
Part number SW: 6C1 909 144 AG, HW: 6C1 909 144 D.
Part: EPS_TRW_ALow 312 3232
Serial number: CF6O1045
Encoding: 000700
Operating number: WSC 73430 790 00063
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6DD5B08ABCD9BD220E-8038
Address 55: Headlight range control (J431) Label file:| DRV\5Q0-907-357.clb
Part number SW: 5Q0 907 357, HW: 6R0 907 357 A.
Component: LWR-ECU 005 0080
Revision: -------- Serial Number: --------------
Encoding: 02CA000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E598EAD48975E2F6-8020
Address 5F: Information selection. I (J794) Label filehttps://shop.dieselschrauber.org/en DRV\5F0-035-MIB-STD2.clb
Part number SW: 5QA 035 846 Hardware number: 5QA 035 846
Part number: MU-S-N-ER H24 0241
Serial number: SEZAZ2R0197632.
Encoding: 04520101BE00000011110001000808002F0200C401200100C6
ASAM Dataset: EV_MUStd4CTSAT 001022
FILE: EV_MUStd4CTSAT_VW36.rod
VCID: 010DFC3A90414942DA-8054
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 5F0 919 604 A, HW: 5F0 919 604 A.
Component: ABTm_Std2_Nav H43 1028
Serial number: SEZ8Z9RFT001M1
Data storage devices:
Subsystem 2 - Part number SW: 6P0 919 866 HW: -----------
Component: ECE 2015/16 --- 0430
Serial number: --------------------
"1 error found:"
U1101 00 [009] - -
Error priority: 4
Error frequency: 1
Lost Count: 203
Mileage: 58,574 km
Date: 2019.06.08
Time: 00:07:28
Voltage at terminal 30: 12.1 V.
dieselschrauber likes this.
Post18-06-2019, 7:47    Subject: Component protection active since the control unit was replaced Quote
VCDS cannot bypass component protection.
I suspect this can only be obtained from a VAS dealer.
Post19-06-2019, 9:17    Subject: Component protection active since the control unit was replaced Quote
This topic is locked, you cannot edit or reply. BKD Won't Start After ZK Renewal On-Board Diagnostics (OBD)
No new posts VCID Meaning: Explained in ECU Log Files On-Board Diagnostics (OBD)
No new posts Strong vibrations since the accident! Transmission, Chassis, Body & Interior
No new posts DPF Regeneration: Problem after 2000 km? Diesel Engine Technology
