Ansteuerdauer + Kalibrierdrücke, euere Werte sind gefragt | Posts 32+
Go to page: Previous  1, 2, 3, 4  Next
HansH
dieselschrauber likes this.
Post03-12-2017, 9:24    Subject: Quote
2013 Passat B7 Estate/Wagon.
CFGB 2.0 TDI-CR 125 kW.
122,000 km
Abnormalities: None.
Diesel update: No.
 File size:  175.38 KB
 Viewed:  2695 times
2013 Passat Variant Highline 2.0TDI (170/CFGB) 4Motion DSG6
Translated on 04-08-2026, 10:08.
Variweiss
2011 Volkswagen Passat
Post14-02-2018, 12:36    Subject: CFFB Engine: Specs, Performance & Review Quote
Passat B7 Estate (Variant), first registration: 02/2011.
Abnormalities: none so far.
Mileage: 171,600 km
Replaced EGR valve at 150,000 km.
Diesel update: No.
 File size:  19.98 KB
 Viewed:  2571 times
Passat 7 MKB:CFFB SG EZ 2011
Translated on 04-08-2026, 10:09.
dieselschrauber and Robomann likes this.
Post14-02-2018, 19:33    Subject: Quote
The topic of "ms" and "µs" was briefly mentioned earlier. It's likely that both refer to microseconds, but with older motor types, the character set used in the computer (or by the programmer) might not have recognized the "µ" symbol. Sometimes, Americans also use "ms" to denote microseconds.
Since the injection durations and intervals are also on the order of 100 µs, correction values in the µs range only make sense.
Translated on 04-08-2026, 10:10.
Post15-02-2018, 10:20    Subject: Quote
Herbert wrote:
Americans sometimes also like to write "ms" for microseconds.
"m for micro" is not a term that I am familiar with, either in English-speaking or German-speaking contexts.
If special characters are not supported, I know that "u" can be used as a synonym for "µ".
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 04-08-2026, 10:12.
Post15-02-2018, 17:34    Subject: Quote
We agree that milliseconds don't make sense, right?
The values describe the correction of the duration of the pilot or pre-injection phases (see also some Bosch patents) at various rail pressures, which are in the order of 100 µs (at least for the CJCD). In addition to the IMA values, this is intended to compensate for the aging of the injectors.
But you already know that.
Sure, here's the translation:
"Best regards," or "Sincerely," (depending on the context).
Translated on 04-08-2026, 10:13.
Avatar-Jan6K
Post12-04-2018, 20:45    Subject: Quote
Are there any findings yet regarding the evaluation?
I've also read out some values now.
Engine: CFHF
Mileage: 67600
Diesel update: YES.
Problems: No.
Feature: Mostly short distances.
"The notation x/y refers to injector x and rail pressure calibration time point y, with VCDS providing these values in microseconds."
Code:
1/1 -26,15
1/2 -14,80
1/3 -15,10
2/1 -38,90
2/2 -15,35
2/3 -18,30
3/1 -41,65
3/2 -19.35
3/3 -15,95
4/1 -33.55
4/2 -12,15
4/3 -18,55
The values seem more negative than most of the ones that have been posted so far, but there weren't many engines from the second generation of the CR series included in those comparisons.
For reference, here are the idle injection volume deviations, respectively in mg/cycle:
Code:
-0,15 0,07 0,09 0,00
Rainer once wrote: "Values below 2 mg/H are good..." which is certainly more than fulfilled here.
January.
1Z5 CFHF / AHB H4D
Translated on 04-08-2026, 10:15.
Post10-01-2020, 18:10    Subject: Quote
A4 8K, CJCD 150 hp, approximately 115,000 km.
Injector 1:
- Common rail pressure calibration point 1: -27.30 µs
- Common rail pressure calibration point 2: -12.95 µs
- Common rail pressure calibration point 3 - 8.95 µs
Injector 2:
- Common rail pressure calibration point 1: -20.35 µs
- Common rail pressure calibration point 2 - 9.55 µs
- Common rail pressure calibration point 3 - 6.00 µs
Injector 3:
- Common rail pressure calibration point 1: -16.90 µs
- Common rail pressure calibration point 2 - 9.85 µs
- Common rail pressure calibration point 3: -11.30 µs.
Injector 4:
- Common rail pressure calibration point 1 + 7.35 µs
- Common rail pressure calibration point 2: -20.20 µs.
- Common rail pressure calibration point 3: -20.60 µs.
No other abnormalities were observed.
The values for 48,000 km are on page 1, in post 6.
Translated on 04-08-2026, 10:19.
Post23-01-2020, 9:00    Subject: Quote
After resetting the values of injector 3 and injector 4 as described in https://community.dieselschrauber.org/en/viewtopic.php?t=30733, and after driving approximately 400 km, the values for my A4 8K, CJCD are now...
Injector 1:
- Common rail pressure calibration point 1 - 18.75 µs.
- Common rail pressure calibration point 2 - 11.55 µs.
- Common rail pressure calibration point: 3 - 5.85 μs.
Injector 2:
- Common rail pressure calibration point 1 - 26.15 µs.
- Common rail pressure calibration point: 2 - 10.15 µs.
- Common rail pressure calibration point: 3 - 6.00 µs.
Injector 3:
- Common rail pressure calibration point 1 - 0.00 µs
- Rail pressure calibration point 2 - 3.90 µs
- Rail pressure calibration point: +0.45 µs.
Injector 4:
- Rail pressure calibration point 1 + 11.45 µs.
- Rail pressure calibration point 2 - 1.90 µs
- Common rail pressure calibration point: 3 - 12.40 µs.
The values for 3 and 4 increase gradually, with the value for 3 increasing very slowly.
Translated on 04-08-2026, 10:23.
wolle
Post08-08-2020, 9:34    Subject: Quote
Hello everyone,
Here are the values from my 2012 Audi A6 (4G) with 245 horsepower, engine code CDUC, and a mileage of 275,000 km.
"For approximately the last 10,000 kilometers, I have been using about 200-300 ml of two-stroke oil mixed with each tank of fuel."
The engine is running, but it has a jerky acceleration at full throttle, and noticeably less power in that range.
The engine starts perfectly and it doesn't smoke.
Here are the values now, expressed in microseconds:
Injector 1, rail pressure calibration point: -7.70.
Injector 1, rail pressure calibration point: -15.40.
Injector 1, rail pressure calibration point: -21.25.
Injector 2, rail pressure calibration point: -1.95.
Injector 2, rail pressure calibration point: -11.95.
Injector 2, rail pressure calibration point: -15.50.
Injector 3: Rail pressure calibration point: -1.05.
Injector 3: Rail pressure calibration point: -10.10.
Injector 3: Rail pressure calibration point: -13.50.
Injector 4, rail pressure calibration point: -15.35.
Injector 4, rail pressure calibration point: -20.80.
Injector 4, rail pressure calibration point: -25.95.
Injector 5, rail pressure calibration point: -2.20.
Injector 5, rail pressure calibration point: -12.30.
Injector 5, rail pressure calibration point: -21.90.
Injector 6, rail pressure calibration point 1: 3.95.
Injector 6: Rail pressure calibration point: -10.70.
Injector 6: Rail pressure calibration point, value -10.55.
Translated on 04-08-2026, 10:29.
wolle
Post05-04-2021, 13:08    Subject: Car Value After Trade-In: What to Expect? Quote
Hello everyone,
I hope you had a HAPPY EASTER icon_smile.gif.
Here are the values from my current 3.0 A6 (4G) 320HP BiTDI from 2018, with engine code CVUC and a mileage of 71,000 km.
Below, I have also included the values for the fuel injection quantity deviation.
I would be very grateful for an assessment of the values mentioned.
If this is not appropriate for this thread, please let me know via private message.
You often read that "higher" values in the positive range indicate coking.
However, I can't find anywhere what exactly would constitute a "larger" value in the positive range.
Do you perhaps have any information for me on that?
Here are the values for the rail pressure calibration points in microseconds:
Injector 1, Rail Pressure Calibration Point 1: 32.30.
Injector 1, rail pressure calibration point: 5.05.
Injector 1, rail pressure calibration point: 21.40.
Injector 2, rail pressure calibration point 1: 20.30
Injector 2, rail pressure calibration point 2: 11.35.
Injector 2, rail pressure calibration point 3: 25.80.
Injector 3, rail pressure calibration point 1: 17.25.
Injector 3, rail pressure calibration point 2: 9.75.
Injector 3, rail pressure calibration point 3: 25.30.
Injector 4, rail pressure calibration point 1: 10.55.
Injector 4, rail pressure calibration point: -0.55.
Injector 4, rail pressure calibration point 3: 18.20.
Injector 5, rail pressure calibration point 1: 3.50.
Injector 5, rail pressure calibration point 2: 6.10.
Injector 5, rail pressure calibration point 3: 24.75.
Injector 6: Rail pressure calibration point 1: 14.00
Injector 6: Rail pressure calibration point 2 - 8.50.
Injector 6, rail pressure calibration point 3: 28.00.
The deviation in injection amounts (in milligrams) is as follows:
Cylinder 1: -0.29
Cylinder 2: +0.50
Cylinder 3: -0.09
Cylinder 4: -0.14
Cylinder 5: +0.13
Cylinder 6: -0.08
Wool.
Translated on 04-08-2026, 10:36.
Post23-05-2021, 4:47    Subject: Quote
A4 8K, CJCD engine with 150 horsepower, currently at approximately 140,000 km.
Injector 1:
- Common rail pressure calibration point: -30.75 µs.
- Common rail pressure calibration point: -11.05 µs.
- Common rail pressure calibration point: 3 -6.75 µs.
Injector 2:
- Common rail pressure calibration point: -10.85 µs.
- Rail pressure calibration point: -9.20 µs.
- Common rail pressure calibration point: 3 - 5.55 µs.
Injector 3:
- Common rail pressure calibration point 1: -22.90 µs
- Common rail pressure calibration point: -8.15 µs.
- Common rail pressure calibration point: 3 -7.65 µs.
Injector 4:
- Common rail pressure calibration point 1: -6.20 µs
- Common rail pressure calibration point: -18.05 µs.
- Common rail pressure calibration point: -21.25 µs.
No other abnormalities detected.
Translated on 04-08-2026, 10:43.
Post02-08-2021, 7:31    Subject: Quote
Hi there,
Is there a Technical Product Information (TPI) available on this topic yet? My last search on the Audi/Erwin website, specifically for my A4, didn't yield any results. Perhaps there is one for V6 TDI engines or other models.
Translated on 04-08-2026, 10:45.
Stefan-5E5
2013 Skoda Octavia
Post01-02-2022, 10:33    Subject: Settling Time & Calibration Pressure Quote
Hello everyone,
Here are the values for my Octavia 5E5 4x4 CKFC.
Series 150 hp / 320 Nm, chip tuning to 181 hp / 398 Nm, 191,000 km mileage, occasional slight jerking in the partial load range below 1500 rpm, unfortunately mostly used for short trips up to 15 km.
Currently noticeable: the injector correction value for cylinder 4 is unusually high during idle and partial load conditions.
This one ranges from 0.57mg to 0.73mg, while the others range from -0.1mg to -0.3mg.
Rail pressure calibration times 1/2/3 in µs.
Cylinder 1: -23.6 / -28.4 / -24.0
Cylinder 2: -0.8 / -22.0 / -21.6
Cylinder 3: -23.2 / -26.8 / -20.8
Cylinder 4: 20.0 / -22.4 / -20.4
Stefan.
Skoda Oktavia 3, 4x4, CKFC, Serie 150Ps/320Nm, Chip ca. 180PS/400Nm.
Translated on 04-08-2026, 10:48.
Post01-02-2022, 20:52    Subject: Actuation Time & Calibration Pressure Explained Quote
Stefan-5E5 wrote:
Notably at the moment: the injector correction value for cylinder 4 is significant during idle and partial load conditions.
This one is between 0.57mg and 0.73mg, while the others are between -0.1mg and -0.3mg.
It's all good. / Everything is fine. / It's under control.
Translated on 04-08-2026, 10:50.
GTS
Post05-07-2022, 21:21    Subject: Quote
CR TDI 2.0 CFFB
Mileage: approximately 130,000 km.
No abnormalities detected except for the presence of diesel fuel in the oil or an increase in oil level.
I'm thinking this will probably result in 4 new [products/releases/etc.]... Does anyone have any recommendations?
 File size:  4.89 MB
 Viewed:  576 times
 File size:  75.27 KB
 Viewed:  562 times
Translated on 04-08-2026, 10:51.
Bimbes
Post14-12-2022, 11:45    Subject: Hello Servus: A Friendly German Greeting Quote
Here is my information.
2.0 TDI A3 8V Quattro Sportback 2013.
130,000 km
No abnormalities.
However, I can't really do anything useful with the data.
I'm not sure if they are okay.
Best regards, Bimbes.
 File size:  3.95 MB
 Viewed:  476 times
 File size:  5.09 MB
 Viewed:  483 times
Translated on 04-08-2026, 10:52.
No new posts Important: Ash content and mileage - your input is needed Diesel Engine Technology
No new posts Chiptuning: Tuning Time & Calibration Pressure Impact Diesel Engine Technology
This topic is locked, you cannot edit or reply. Fuel Injectors: Flow Rate & Duration Data Needed Diesel Engine Technology
No new posts Golf V TDI Towing: Experiences & Tips Needed! Diesel Engine Technology
