Wozu ist dieser Schlauch am LuFi-Kasten? | Posts 16+
Go to page: Previous  1, 2
Steffen W
Karma: +104 / -0   Thank you, like it!
dieselschrauber, Herbert and Mpire likes this.
Post06-02-2020, 20:54    Subject: Quote
You can also seal the cut-off stub with two components of modeling clay (e.g., Petec Powerstahl) or with a screw. Attach a small inline filter to the vacuum hose, as shown in the middle of the picture. The picture on the right shows the same filter, but with the housing removed. This is not a paper filter, but one with a very fine mesh.
Alternatively, you can drill out the broken stub and glue a straight pipe connector using the putty or another suitable adhesive. Then, you can reattach the vacuum hose to the connector as usual.
 File size:  16.46 KB
 Viewed:  621 times
Passat Variant BGW 2005
Translated on 03-10-2026, 15:16.
No new posts Wohin kommt dieser Schlauch beim AMF? Diesel Engine Technology
No new posts Turbocharger Boost Hose: Connection & Oil Issues Diesel Engine Technology
No new posts Upgrading MFL Caddy box 2018 - Error 31 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Vacuum Pneumatic Connection LuFi Upload
