Fuel sensor Passat 3B Syncro/4Motion
dleds
Karma: +14 / -1   Thank you, like it!
Post17-03-2020, 10:59    Subject: Fuel sensor Passat 3B Syncro/4Motion Quote
Hello everyone,
I've been having a problem for a while now with a friend's 1997 30V Passat Variant, where the fuel gauge is malfunctioning (it shows 0 liters).
Since he's unable (despite usually being quite capable) to either refuel in kilometers or carry a jerrycan, I had to tow him yesterday three times...
Now I've had the car for 3 days, and it's incredibly frustrating. When I use a 330 Ohm resistor instead of the sensor, everything works fine, and it consistently displays "full" for extended periods. I'm therefore running out of fuel due to a fault in the tank.
Okay, so I removed the cap from the sensor, and lo and behold, there were two sensors connected in series.
After that, I removed the 330 Ohm resistor and installed a 220 Ohm resistor in place of one of the sensors (the display showed approximately 3/4 after startup). Test drive completed, and the "beep 0 liters" indicator suddenly went back to zero.
Then, the other donor was connected. Same story...
Then I lifted the seat on the driver's side, expecting to find a "blind plug," but instead, there was an open connection. After accounting for that, the sender unit connection at the tank (passenger side) is also showing high resistance, so it's likely related to the tank itself.
Now, to my question: It's not possible to find this information in the Erwin (siehe Fehlerdatenbank) documentation, but does this tank have approximately 3 tank sensors? icon_eek.gif
And the next question is, how exactly are we supposed to get it out of the tank without completely destroying it? It physically doesn't fit through the hole.
Karma: +645 / -0   Thank you, like it!
dieselschrauber likes this.
Post17-03-2020, 17:35    Subject: Fuel sensor Passat 3B Syncro/4Motion Quote
The vehicle has two fuel pumps, but the relevant sensor that tends to fail because the contact surface is worn is located on the passenger side.
Upgrade? No idea. My Passat TDI 4-Motion has the same thing installed, but everything is still working fine here.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Vibrations and Rumble Noises with 4Motion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Passat TDI: Combination Instrument Board Repair Transmission, Chassis, Body & Interior
No new posts VW Passat 4Motion: AVF Engine Idler Pulley Diesel Engine Technology
This topic is locked, you cannot edit or reply. Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Transmission, Chassis, Body & Interior
No new posts Passat 3B 4Motion: Wobbly, Breaks Loose When Braking Transmission, Chassis, Body & Interior
