Polo 6N ABS Drehzahlfühler | Posts 16+
Go to page: Previous  1, 2
vag-driver
dieselschrauber likes this.
Post17-10-2018, 19:06    Subject: Quote
olli wrote:
Why necessarily in the control unit? I would rather suspect the cable or the crimped contacts...
This is the remaining 1% uncertainty icon_cool.gif.
It is indeed extremely difficult to locate the source of the error. Since I only lightly tapped the sound generator (SG) with the screwdriver handle and was thus able to reproduce the error, this explanation seemed most likely to me.
I've already pulled on the cables quite a bit, and the connectors look fine to me.
My plan is to replace the entire block with a new one from an ET donor vehicle as soon as I have some time.
Andreas
Translated on 16-07-2026, 16:49.
vag-driver
Post22-10-2018, 8:05    Subject: Quote
In short: this weekend I replaced the ABS module. I had lost confidence in the ABS system because the pump was activating even with light braking.
Since the replacement, I've driven about 150 km without any issues. I hope it stays that way!
Andreas
Translated on 16-07-2026, 16:50.
Karma: +645 / -0   Thank you, like it!
Post22-10-2018, 8:06    Subject: Quote
I'm familiar with active ABS engaging during light braking, which can happen if the distance between the sensor and the toothed wheel is incorrect or if the toothed wheel is damaged.
vag-driver
Post22-10-2018, 8:39    Subject: Quote
The error pattern was so bizarre afterwards that I didn't know what to do anymore. I even heard the ABS pump once while driving, without braking icon_eek.gif.
BTW:
Of course, I reconnected the intact sensor to the ABS connector.
Andreas
Translated on 16-07-2026, 16:51.
vag-driver
dieselschrauber and brezelmann01 likes this.
Post05-05-2020, 21:54    Subject: Quote
The ABS hydraulic unit that was already replaced has started malfunctioning again. The error code in the diagnostic memory is exactly the same as it was before.
00283 - Front wheel speed sensor, left side (G47).
35-10 - - - Sporadic
16-10 - Signal out of tolerance - Intermittent.
After that, I reassembled the block, opened the control unit housing, and resoldered all the contacts on both connectors. One of the solder joints to the pump was even broken.
I resealed the lid using Sika 221 (which my neighbor happened to have on hand).
The error is now finally fixed. It's a shame I disposed of the control unit back then. It almost certainly had the same problem.
Andreas
Translated on 16-07-2026, 16:52.
Post06-05-2020, 18:09    Subject: Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Translated on 16-07-2026, 16:54.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with ABS wheel speed sensor on Audi A6 C4 Transmission, Chassis, Body & Interior
No new posts ABS Light On: Faulty Speed Sensor - Cost? Diesel Engine Technology
No new posts VW Polo TDI: Specs, Features, & More Diesel Engine Technology
No new posts Polo 6R On-Board Diagnostics (OBD)
