david7x64
Joined: 10/27/2013 Posts: 5 Karma: +0 / -0 Location: Willich
11-05-2020, 19:20 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
Hello, I'm experiencing the following problem with a Tiguan 1 with the 170hp CBBB engine:
The engine is not taking fuel well and has less power at low speeds. Jerks severely.
The injectors would be replaced and reprogrammed after a complete overhaul.
The engine initially ran better, but then only ran very poorly. We then performed a compression test. Result: Cylinder 1 and 2: No! (0) Compression.
What could it be? The car needs to go to the workshop next week. Does anyone have an idea?
Best regards, David
Held467 Blaumann
11-05-2020, 20:29 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
It's likely that the head gasket has blown.
Best regards.
Joined: 04/12/2002 Posts: 18099 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
11-05-2020, 21:46 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
Without compression on individual cylinders, the only solution is to remove the head. The injectors and spark plugs should hopefully be installed correctly and be airtight, which is easy to see.
Best regards, Rainer
Profile PM WWW Garage |
aquablader
03-08-2021, 15:58 Subject: Curiosity |
And, what was the ultimate reason, then? I'm facing a similar situation: the first two cylinders have no compression, the cylinder head is removed, the valves appear to be okay, and the piston crowns appear to be okay.
VG Ingo
david7x64
03-08-2021, 16:07 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
Hi, the headpiece was broken. Burned through between the cylinders.
Most likely caused by the poor injectors.
aquablader
03-08-2021, 16:12 Subject: Thank you. |
Thank you for the response.
The poem was okay here...
matthiasTDI96 Profi-Schrauber
06-08-2021, 8:16 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
Then the device was faulty or it was used incorrectly…
aquablader
06-08-2021, 9:29 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
What are you trying to tell me?
Herbert likes this. |
06-08-2021, 15:58 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
If the light bulbs are installed and sealed, and the valves are closed and sealed. If the cylinder head gasket and the cylinder head itself are undamaged, the piston is in place and moving, then there is nothing left but a measurement error, or?
aquablader
06-08-2021, 16:02 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
Who says that the pistons are in good condition? There were, in fact, two rings broken.
However, at the time the post was created, I didn't know this and therefore inquired further.
david7x64
06-08-2021, 17:32 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
If the light bulbs are installed, you cannot measure compression...
dieselschrauber likes this. |
07-08-2021, 7:09 Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. |
Okay, as of August 3rd, nothing had been written about it yet. Then the cause has been found.
Of course, it is correct that the light bulbs are removed for measurement purposes. Then I remove the light bulb and say injector.
But it's great that it's been resolved.
