Audi A6 2,5 TDI BDG stottert bei Teilllast obwohl VP44 neu | Posts 16+
Go to page: Previous  1, 2
Adel
Post17-08-2020, 8:09    Subject: Quote
Update:
Yesterday, I replaced all the hydraulic lifters, including the rocker arms.
Some of the linkage levers were quite worn on the "Hydrositz" (hydraulic seat), so we replaced them all at the same time.
The timing belt has been replaced and properly tensioned.
The "egg-shaped" camshaft gear was also replaced.
Conclusion: The engine is running just as poorly as before. icon_sad.gif
There is still a significant difference between the desired and actual injection start time (see attached image).
I was also told that the injection amount is far too high, at 7.2 mg/H (see the attached image).
For a vehicle with the same design, even with a newly refurbished pump, the injection quantity is 5.0 mg/H.
I'm now quite certain that my newly refurbished fuel injection pump is the cause, or what do you think?
I will return the pump to the company for a re-inspection.
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
 Differenz zw Soll/Ist beim Einspritzbeginn und zu hohe Einspritzmenge.
 File size:  252.28 KB
 Viewed:  1112 times
Translated on 27-09-2026, 12:49.
Post17-08-2020, 20:21    Subject: Quote
Check the start of injection using VCDS and the TDI timing checker.
It's best to post a Screenshot.
I've just scrolled through the topic again, and I don't see anything about setting the start of the injection. I mean, it doesn't just happen automatically; you have to do something to initiate it. icon_wink.gif
Translated on 27-09-2026, 12:51.
Adel
Post17-08-2020, 21:10    Subject: Quote
Hello, I have set the injection start point to -2.0.
I've already removed the pump; it will be returned tomorrow.
I will report back after it has been checked.
The start of injection still showed a significant difference between the target value and the actual value.
"Lg" is a German abbreviation that stands for "Liebe Grüße," which means "Best regards" or "Warm greetings" in English.
Translated on 27-09-2026, 12:52.
Post20-08-2020, 20:55    Subject: Quote
Adel wrote:
Hello, I have set the injection start point, and it is currently at -2.0.
And was the injection timing stable in the graph from the TDI timing checker?
Translated on 27-09-2026, 12:53.
Adel
dieselschrauber likes this.
Post15-02-2021, 10:57    Subject: Quote
Please excuse the delay...
I wouldn't want to keep the solution to the problem from you.
It was actually due to the "new" fuel injection pump.
I returned it and received a new one, installed it, and everything is working perfectly!
It definitely cost me a lot of nerves, but now it's working again like it should icon_smile_thumb_up.gif.
Translated on 27-09-2026, 12:54.
Post15-02-2021, 18:24    Subject: Quote
No new posts VP44 fuel injector on Audi A6 AKN model drawing air, caus... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Audi A4 B6 VP44 replaced, now showing code P1841 On-Board Diagnostics (OBD)
No new posts Audi 2.5 TDI VP44: Excessive Smoke? Dieselschrauber Bar
No new posts 1Z stutters Diesel Engine Technology
No new posts Oil Light On? Troubleshooting & Solutions Electrical Systems, Vehicle Electronics, Multimedia
