Replace Engine Control Unit (ECU)
Zapfenduese
Post22-07-2020, 15:18    Subject: Replace Engine Control Unit (ECU) Quote
Hello.
I have an Audi A4 8E 2.0 TDI with engine code BRD, manufactured in 2006.
Problem: Engine misfires / stalls intermittently. So far, it has been possible to restart it with varying degrees of difficulty. If it stalls at idle, no error code is stored. If it stalls under load, codes P1260, P1263, and P1266 are present.
The engine wiring harness has been replaced, but there is no change. According to the Audi authorized workshop, the piezo injectors are defective.
"However, I noticed that the error occurs when I move the engine control unit. Next, I disassembled the control unit, and it's true that the engine shuts off when the circuit board is moved. I contacted a repair company, but they couldn't guarantee they could fix the problem with the control unit. Audi can supply a replacement control unit (03G997058GX)."
Okay, here's the translation:
"Now, to my question. Is it possible or necessary to configure this replacement control unit using VCDS and adjust the immobilizer settings? Or are these settings even plug-and-play, like with Fiat? Audi can't answer this question for me."
Translated on 31-08-2026, 23:12.
Steffen W
Karma: +104 / -0   Thank you, like it!
dieselschrauber and Zapfenduese likes this.
Post23-07-2020, 6:34    Subject: Replace Engine Control Unit (ECU) Quote
That's not going to work with plug and play.
It is possible to pair the device using VCDS. However, there's a catch: it only works if you have the PIN code for the immobilizer. If you're using a new control unit, you only need the PIN code from the car. If you're using a used control unit, you need both PIN codes: the PIN code from the used control unit that you're installing, and the PIN code from the car.
You cannot read these codes with VCDS, and Audi cannot tell you what they are. You need different equipment to read these codes.
If you're buying the part from Audi anyway, then have it installed and programmed there directly. That's probably the easiest solution.
Passat Variant BGW 2005
Translated on 31-08-2026, 23:15.
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
dieselschrauber likes this.
Post26-07-2020, 13:03    Subject: Replace Engine Control Unit (ECU) Quote
There are also companies that can clone your engine control unit (ECU). That would be an alternative... icon_smile_thumb_up.gif
Translated on 31-08-2026, 23:16.
Zapfenduese
Post27-07-2020, 17:21    Subject: Replace Engine Control Unit (ECU) Quote
Thank you for the quick responses.
Ideally, I would be able to find and repair the interruption or loose connection on the circuit board. I have already resoldered the connection points, but the problem still persists. Here are some pictures and a video.
Replace Engine Control Unit (ECU) - 20200727_170812.mp4
 File size:  52.3 MB
 Viewed:  10007 times
 File size:  526.93 KB
 Viewed:  656 times
 File size:  466.03 KB
 Viewed:  642 times
Herbert and Zapfenduese likes this.
Post27-07-2020, 18:18    Subject: Replace Engine Control Unit (ECU) Quote
The problem with your type of control unit is that more or less force and heat need to be applied to open the housing.
It doesn't make things any better.
I can't recall any instances of soldering defects on circuit boards. Instead, in multilayer circuit boards, faulty vias or layer separations are not uncommon.
You can't repair anything there (and neither can most other people, in a way that makes economic sense).
If it were my car, I would: Depending on the year of manufacture, I would either obtain a suitable engine control unit (ECU) as recommended by a chip tuner and have the WFS (Warm Function Start) deactivated, or I would clone the existing ECU.
Otherwise, you risk a complete economic disaster.
Translated on 31-08-2026, 23:17.
tobias_
Post07-09-2020, 8:41    Subject: Replace Engine Control Unit (ECU) Quote
I once bought an original control unit from a reputable auction house "for testing purposes," and the immobilizer was deactivated. It came from Poland and worked perfectly as a plug-and-play solution. I paid about 100 CHF for it. Simply enter the part number of your control unit on eBay. I estimate the chance that the car will be stolen due to the missing immobilizer is rather low icon_smile.gif.
Audi A4 B6 Avant 1.9TDI (AVF) Quattro S-line komplett
Translated on 31-08-2026, 23:19.
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post07-09-2020, 9:24    Subject: Replace Engine Control Unit (ECU) Quote
I had a good experience with Tachopix in Hanover.
Typically, we provide a cost estimate after inspecting the control unit. Then you can decide whether it's worth it and feasible.
Since the company is located 40km away, I drove there with my control unit (after making an appointment). The Espace is known to have problems with certain chips. After the diagnosis, I was told that the chip was okay. So, it wasn't repaired unnecessarily. The problem was actually with my display, which was then fixed a few weeks later.
Best regards.
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 31-08-2026, 23:20.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace engine control unit (ECU) for VW Passat B7, 2014,... Gasoline Engine Technology
No new posts Turbocharger Replacement: How to Replace It Diesel Engine Technology
No new posts Replace V6 Injectors: Guide & Parts Diesel Engine Technology
No new posts Replace battery? Electrical Systems, Vehicle Electronics, Multimedia
