hkss Blaumann
Joined: 12/17/2006 Posts: 171 Karma: +13 / -0 Location: Karlsruhe 2017 Skoda Yeti Premium Support
21-11-2020, 9:21 Subject: Heater Not Starting? Troubleshooting Date Issues. |
Skoda Yeti TDI, 150 horsepower, year 2017.
The auxiliary heater is not starting.
I used VCDS to read the error code.
I've noticed that the date is incorrect (2045.14.31).
The temperature is the same.
It was -1 degree Celsius, but the record shows 15 degrees.
The day of the week is no longer displayed correctly in the MFA (Multi-Factor Authentication) interface.
I'm attaching the complete scan from yesterday (without any errors).
and the PDF error memory from the control unit "auxiliary heater".
I didn't want to do a complete scan again, as everything else is unchanged from yesterday.
"Because I noticed the incorrect date, it reminded me that about a week ago, I started my car in the morning and realized that the time was off by 2 hours and 20 minutes. Also, all the data from the MFA (Multi-Function Display), such as total mileage, average fuel consumption, average speed, etc., was gone. I noticed this because I had just filled up the tank the night before and always reset everything to zero after refueling, but I had already driven 30 kilometers. This was the first time something like this happened to my car in almost 5 years."
Does anyone have any ideas?
| Description: |
| Komplettscan ohne Fehler vom Vortag. |
 Download |
| File name: |
Log-KA HK-556-TMBLD75L8H6029008-76720km-Kohl.txt |
| File size: |
14.31 KB |
| Downloaded: |
477 times |
| Description: |
| nur der Teilauszug vom Steuergerät "Standheizung" von heute, also nach dem noch fehlerfreien Komplettscan von gestern. |
 Download |
| File name: |
Standheizfehler.pdf |
| File size: |
103.17 KB |
| Downloaded: |
469 times |
Translated on 14-10-2026, 15:44.
Profile PM Garage |
21-11-2020, 9:52 Subject: Heater Not Starting? Troubleshooting Date Issues. |
I have seen incorrect date or time information in the environmental conditions  more than once in various control units. However, I cannot tell you whether the data is being stored incorrectly or whether it is being misinterpreted. 2 hours 20 minutes }
Loose connection at the fuse or cable connection to the battery causing a 2 hour and 20 minute power outage?
Should the auxiliary heater be explicitly activated (using the clock/manual controls), or was it an automatic start by the auxiliary heater due to cold coolant?
Translated on 14-10-2026, 15:46.
Profile PM WWW Garage |
hkss Blaumann
21-11-2020, 10:16 Subject: Heater Not Starting? Troubleshooting Date Issues. |
It was a deliberate start using the button in the center console. This morning, I approached the car and the windows were frosted. It started briefly as usual, with a slight smell, then turned off again after a maximum of 1 minute. Later, while driving, I pressed the button again, and the indicator light on the button immediately went out after I released it.
Translated on 14-10-2026, 15:47.
Profile PM Garage |
21-11-2020, 10:19 Subject: Heater Not Starting? Troubleshooting Date Issues. |
"Yes, that's a shame. Then the auxiliary heater should actually indicate where the problem lies... for example, flame failure, failure to ignite, or low battery voltage, etc."
Translated on 14-10-2026, 15:48.
vag-driver Profi-Schrauber
22-11-2020, 12:15 Subject: Heater Not Starting? Troubleshooting Date Issues. |
I'm not entirely clear yet about the conditions under which the SHZ (presumably a piece of equipment) fails to start.
Is the SHZ (auxiliary heating unit) factory-installed or an add-on?
2. In what operating state does it not function? Specifically, I'm asking whether the engine is running or not.
3. Is the SHZ locked? If so, it must be unlocked before further tests can be performed.
I would disregard the incorrect date for now.
Andreas
Translated on 14-10-2026, 15:49.
hkss Blaumann
22-11-2020, 16:23 Subject: Heater Not Starting? Troubleshooting Date Issues. |
1. was pre-installed from the factory.
2. I tried it once before starting the engine, and once after the engine had been running for a few minutes.
3. Nope...
In short, I searched for and found the FFB (presumably a specific button or interface), pressed the "Start" button on it, and it's working!
Läuft (startet) jetzt auch auf Knopfdruck in der Mittelkonsole. Everything is normal.
I suspect that the initial attempts to start the engine after an 8-month break failed because the diesel fuel line might have been empty.
"Thank you anyway for your willingness to help!"
Translated on 14-10-2026, 15:50.
Profile PM Garage |
dieselschrauber likes this. |
22-11-2020, 19:31 Subject: Heater Not Starting? Troubleshooting Date Issues. |
hkss wrote: |
Certainly not, otherwise many people would have this problem. Fortunately, the SHZ is working again. Hopefully, it will stay that way.
Andreas
Translated on 14-10-2026, 15:51.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
dieselschrauber and hkss likes this. |
23-11-2020, 18:30 Subject: Heater Not Starting? Troubleshooting Date Issues. |
Evening.
Just a quick tip on the side.
The auxiliary heater should also be used once in the summer.
Started monthly.
The fan in the heating system tends to get stuck if it's not used for a long time.
Then it usually smokes because there isn't enough air supply.
Translated on 14-10-2026, 15:52.
Profile PM Garage |
