AJM Leistungsverlust kein Ladedruck | Posts 48+
Go to page: Previous  1, 2, 3, 4
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Steffen W
Karma: +104 / -0   Thank you, like it!
dieselschrauber likes this.
Post13-09-2020, 8:42    Subject: Quote
Sharquu wrote:
It's producing quite a bit of smoke. How is that possible?
Exactly. The Passat with the BGW engine comes with a regulated catalytic converter from the factory. Is yours still active?
Passat Variant BGW 2005
Translated on 08-07-2026, 20:48.
Sharquu
2004 Volkswagen Passat
Post13-09-2020, 9:40    Subject: Quote
Steffen W wrote:
Eben.Wo doch der Passat mit BGW Motor einen geregelten Russfilter ab Werk hat.Ist der bei Dir noch aktiv?
No, it's deactivated.
Translated on 08-07-2026, 20:49.
Steffen W
Post13-09-2020, 14:12    Subject: Quote
Someone has likely tampered with the engine control unit's data set. Any further discussion regarding troubleshooting this model is essentially a waste of time.
Translated on 08-07-2026, 20:50.
Steffen W
Post13-09-2020, 14:19    Subject: Quote
Okay, let me clarify my point further, with the (admittedly vague) hope of avoiding the usual objections that are typically raised in this context:
We don't know which addresses in the dump have been modified.
Only the person who did it knows. And if it were my car, I would definitely ask that person about the Russian education and related things.
Translated on 08-07-2026, 20:51.
jo123422
Post17-01-2021, 14:36    Subject: Quote
I can't contribute anything more; I've completely abandoned the car.
It was definitely time to change the winter tires, but when I lowered the jack, it sank 5cm into my car's rocker panel...
It was a really nasty mistake...
I had the charging cable replaced. I've tried a total of 3 different LMM (likely referring to a mass airflow sensor).
"There was never a mistake."
I have a stainless steel Porsche 911 (992) with full options and it's relatively rust-free.
Got it for 1700, 2nd owner, 160,000 km (verifiable).
Well-maintained service history – what more could you want!
Translated on 08-07-2026, 20:52.
dieselschrauber, brezelmann01 and Turbinchen likes this.
Post19-01-2021, 10:18    Subject: Quote
Ahhh.
The new one is rust-proof... relatively rust-proof. Hopefully, the rest is definitely so, and not also relatively icon_wink.gif at the end.
Translated on 08-07-2026, 20:53.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intermittent lack of boost pressure, 1.8T AUM Gasoline Engine Technology
No new posts V70, no turbo boost, D5 engine, 163 hp Diesel Engine Technology
No new posts A4 1.8T AEB - No boost / power Gasoline Engine Technology
No new posts Polo BMS kein Ladedruck Diesel Engine Technology
