VCSCOPE.EXE Error: Troubleshooting Diagram Issues
topf20
Post16-02-2021, 16:06    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Hello.
"For some time now, I've been getting the error message "Can't spawn VCSCOPE.EXE" when opening diagrams in Block."
Using Windows 7 without any antivirus software.
I have already uninstalled VCDS (V20120-Installer) and KDataScope (KDataScope_222_GER), deleted the Kaufmann and Ross-Tech folders, and reinstalled everything.
The KDataScope program runs through the Start/Programs menu, regardless of whether VCDS is open or not.
Until recently, I was able to display the values in a chart.
[email protected]
Translated on 19-09-2026, 1:22.
vag-driver
dieselschrauber likes this.
Post16-02-2021, 18:59    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Windows 7 support ended in January 2020. Therefore, I highly recommend using a more recent operating system. I only mention this for your information.
It's not unlikely that your Windows 7 is no longer functioning correctly. I recently experienced the same issue with my Windows 10. The only solution is a clean reinstallation.
What I want to express is that the problem might not be with VCDS itself, but rather with Windows.
Andreas
Translated on 19-09-2026, 1:23.
Post16-02-2021, 20:10    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Is Windows Defender also not active? What does the Windows Event Viewer say?
Access to the event log is through the Event Viewer. First, press the key combination [Windows] + [R] to open the Run dialog. Then, in the Run dialog, type the command eventvwr.
Translated on 19-09-2026, 1:24.
topf20
Post16-02-2021, 21:47    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
You're welcome, vag-driver.
That would be a real shame if it's due to Windows 7.
I only use the PC for diagnostics, so should I buy a completely new operating system for that? I'm still considering whether to reinstall Windows 7.
Thank you, Rainer.
Interesting point.
I once marked the folders "Kaufmann" and "Ross-Tech" as excluded files in Defender, but unfortunately, it didn't work.
Regarding the event log: Well, it's all full, and I don't know where to look. I tried starting the chart and searching for entries at that time, but it doesn't seem to show anything.
Translated on 19-09-2026, 1:26.
vag-driver
Post16-02-2021, 22:32    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Reinstalling Windows 7 is a good starting point. Furthermore, a Windows 10 activation key can be purchased for under 20€.
Andreas
Post16-02-2021, 22:57    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Ross-Tech also writes about the possible error messages that can appear in VC Scope:
https://www.ross-tech.com/vag-scope/
Sure, here's the translation:
**Quick instructions, specifically points 1 and 2.**
Translated on 19-09-2026, 1:27.
Post17-02-2021, 8:32    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Dangerous half-knowledge:
I believe that a Windows 7 key is still sufficient to activate Windows 10, which means that a new purchase should not be necessary.
Guste.
Translated on 19-09-2026, 1:28.
vag-driver
Post17-02-2021, 8:46    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
I believe that a Windows 7 key is still sufficient for activating Windows 10.
That means a new purchase should not be necessary. https://www.chip.de/news/Windows-10-kostenlos-Windows-7-Gratis-Update_127005018.html
Upgrading from Windows 7 to Windows 10 is still possible even today with a valid product key.
Andreas
topf20
Post17-02-2021, 16:18    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Hello.
I once tested a laptop with Windows 7 (which, by the way, had FreeAV installed) and only installed VCDS without KDataScope. In this setup, the diagram even works without KData or VcScope.
It seems there's probably something wrong with my workshop PC running Windows.
Let's see if I can find the error, or if it's easier to just start over.
Translated on 19-09-2026, 1:29.
Post17-02-2021, 16:43    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
The VC-Scope distributed with VCDS version 20 is no longer compatible with 32-bit systems. Which version of Windows 7 are you using, and what hardware are you running it on?
The simplest solution is probably to take VC-Scope from an older version.
Translated on 19-09-2026, 1:30.
vag-driver
Post17-02-2021, 16:56    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
topf20 wrote:
Let's see if I can find the error or just "simply" recreate it.
Save yourself time and rebuild the system. Then you'll have a solid foundation again.
Andreas
Translated on 19-09-2026, 1:31.
topf20
Post17-02-2021, 17:38    Subject: VCSCOPE.EXE Error: Troubleshooting Diagram Issues Quote
Yes, I now believe it's due to the old 32-bit computer.
"In any case, the file located at C:/RossTech/VCDS-DRV/VCScope cannot be opened, and I receive an error message indicating that the program requires 64-bit architecture."
Thank you for your support.
I'm looking for a 64-bit computer.
Translated on 19-09-2026, 1:32.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts ASR error message on A4 AFB Diesel Engine Technology
No new posts VCDS error message on a Seat Ibiza 1.6 TDI CR, year 2010 Upload
No new posts TDI BKD: Diagnose, Performance Issues & Data Analysis Upload
No new posts Golf 4 TDI ALH: LMM Log with Diagram Upload
