T6 Caravelle rear heater only blows cold air | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post15-04-2021, 16:19    Subject: T6 Caravelle rear heater only blows cold air Quote
Hello Michael, when checking the heating support pump with VCDS in the actuator diagnosis, the message "-Rejected by the control unit-" appears with the code 7F 2F 7F. Best regards, Wolfgang.
Translated on 06-07-2026, 22:11.
Back to top Profile PM Email
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber and Schmierpfote likes this.
Post15-04-2021, 17:10    Subject: T6 Caravelle rear heater only blows cold air Quote
Hello Wolfgang,
Then it probably won't be supported.
In this case, Rainer is definitely the better person to contact. He not only has VCDS software readily available, but he also has it installed in his T6. So, if anyone can give a definitive answer, it's the boss. Or another happy T6 owner here in the forum.
Then you should try to manually check the pump.
You should be able to feel if it's running. Or, if available, improvise a "stethoscope" by using a long screwdriver.
It is protected by fuse 29, located on fuse holder B next to the battery.
Michael.
Translated on 06-07-2026, 22:12.
Ich_Can_nix likes this.
Post15-04-2021, 17:21    Subject: T6 Caravelle rear heater only blows cold air Quote
Hi.
Unfortunately, I couldn't find any more pictures of that thing on my computer. However, images on the web clearly show that the coolant hoses connect directly to the heat exchanger.
The heat exchanger must therefore warm up at the latest when the engine is running. As far as I know, the auxiliary water pump is only for the auxiliary heater. I have the Climatic system. The Climatronic system is supposed to have an additional valve in the coolant hoses leading to the heat exchanger at the rear. According to the web, at least.
Did you properly secure the valve?
Translated on 06-07-2026, 22:14.
Karma: +1336 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-04-2021, 20:35    Subject: Re: T6 Caravelle rear heater only blows cold air Quote
This could be due to incorrect operation of the VCDS software. For example, it might be unable to log in to the control unit (ECU), the function might be called repeatedly, the ECU might be in an incorrect operating state, or the interface might be outdated and incompatible with the ECU.
Translated on 06-07-2026, 22:15.
Schmierpfote
Post16-04-2021, 7:49    Subject: T6 Caravelle rear heater only blows cold air Quote
Hello forum, thank you for the help. Today, I have access to a lift, and the T6 will be inspected from underneath. Once the panels are removed, I'll be able to access the heater hoses for the rear heat exchanger. Best regards, Wolfgang.
Translated on 06-07-2026, 22:16.
Schmierpfote
Post18-04-2021, 20:31    Subject: T6 Caravelle rear heater only blows cold air Quote
Hello forum, I found the problem. The rear heat exchanger is clogged. I removed the underbody panel near the rear right wheel arch and measured the temperature on the supply and return lines. On a warmed-up T6, the supply line is 47 degrees and the return line is 13 degrees. Best regards, Wolfgang.
Translated on 06-07-2026, 22:17.
Post18-04-2021, 22:18    Subject: T6 Caravelle rear heater only blows cold air Quote
Hello Wolfgang,
Thank you for the feedback! How is that possible? Could there be a problem with the cylinder head, leading to a leak in the cooling system?
Translated on 06-07-2026, 22:18.
Schmierpfote
Post19-04-2021, 7:09    Subject: T6 Caravelle rear heater only blows cold air Quote
Hello Rainer, the T6 has 170,000 km on the odometer and is 4 years and 4 months old. The AGR cooler was replaced free of charge. The clogging of the heat exchanger is supposedly due to coolant G 13. Greetings,
Wolfgang
vag-driver
Post19-04-2021, 10:41    Subject: Re: T6 Caravelle rear heater only blows cold air Quote
Schmierpfote wrote:
Hello Rainer, the T6 has 170,000 km on it and is 4 years and 4 months old. The AGR cooler was replaced free of charge. The clogging of the heat exchanger is supposedly due to coolant G 13. Greetings Wolfgang
"Where does this statement originate, claiming that the cause is the coolant additive?"
Andreas
Translated on 06-07-2026, 22:19.
Schmierpfote
Post19-04-2021, 11:21    Subject: T6 Caravelle rear heater only blows cold air Quote
Hello forum, a workshop manager hinted that the T6 model has these problems more often. There are also reports on YouTube about the G13. Best regards, Wolfgang.
Translated on 06-07-2026, 22:20.
vag-driver
Post19-04-2021, 15:10    Subject: T6 Caravelle rear heater only blows cold air Quote
So, it turns out there are indeed some irregularities. That's why I started this thread.
Okay, I'm ready. Please provide the German text you want me to translate.
Andreas
Translated on 06-07-2026, 22:21.
Post19-04-2021, 18:10    Subject: T6 Caravelle rear heater only blows cold air Quote
vag-driver wrote:
So, there are indeed some anomalies. That's why I started this thread.
/viewtopic.php?t=30875#249171
Bad, maybe replacing the coolant wouldn't be a bad idea...
Schmierpfote
Post21-04-2021, 20:13    Subject: T6 Caravelle rear heater only blows cold air Quote
"Hello everyone, I was at my parts supplier – a large company – and picked up some spare parts. I told the salesperson that I was returning the G13 coolant for my T6 because the heat exchanger is clogged, and I'll be taking G12++ instead. The salesperson said he was surprised I was buying G13, as there was a VW campaign advising against its use. However, there's no clear instruction, with some workshops using G12 and others using G13. Talking to salespeople at wholesale suppliers is better than any training at VW. 200 workshops that have to repair this mess after the warranty period know more than the poor VW mechanics." Best regards, Wolfgang.
Translated on 06-07-2026, 22:23.
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heated, auto-dimming side mirror malfunction General Tips
No new posts Öltemp. und der Mythos um kalte TDIs Diesel Engine Technology
No new posts kalte Temperatur und Rutschende Kupplung Diesel Engine Technology
No new posts T5 Caravelle Fault Code Brake Transmission, Chassis, Body & Interior
No new posts Switching the service interval indicator to longlife mode... Diesel Engine Technology
