Extended Measurement Channels for VCDS via UDS
Post23-04-2021, 10:24    Subject: Extended Measurement Channels for VCDS via UDS Quote
In VCDS, it is possible to load and save sets of extended measurement values.
It is planned to create meaningful compilations on this topic, so that users of VCDS can save themselves from time-consuming searches in the channels, which can contain hundreds of measurement values.
If someone has already made similar collections, it would be great to post them here!
Best regards, Rainer
Karma: +1353 / -0   Thank you, like it!
dieselschrauber likes this.
Post23-04-2021, 16:26    Subject: Extended Measurement Channels for VCDS via UDS Quote
Do you mean the files that are stored in the /Scaling directory, i.e., the usable files in the *.u01 format?
Post23-04-2021, 16:40    Subject: Extended Measurement Channels for VCDS via UDS Quote
Ste.Bo likes this.
Post27-04-2021, 18:33    Subject: Extended Measurement Channels for VCDS via UDS Quote
Hello
Unfortunately, they only allow the storage of the logged UDS values.
So far, it appears that the channel numbers are universally applicable, but not all are present in every device.
Please find the following files for logging purposes.
Benzin - Performance.u01
 Erweiterte Messwerte per UDS.
 File name:  Benzin - Performance.u01
 File size:  89 Bytes
 Downloaded:  479 times
Diesel - Luft, Begrenzungen.u01
 File name:  Diesel - Luft, Begrenzungen.u01
 File size:  71 Bytes
 Downloaded:  580 times
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 17.8.0: Advanced Measurement Data On-Board Diagnostics (OBD)
No new posts VCDS 805.2: Where is the Extended Measurement Channel Block? On-Board Diagnostics (OBD)
No new posts Advanced Measurement Data Overview On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
