Dracula
04-06-2021, 20:10 Subject: Engine control unit cannot be coded for manual transmission |
The engine control unit (ECU) EDC17C46 (03L 906 018 RG), with engine code CFGC, cannot be re-programmed from DSG (dual-clutch transmission) to manual transmission. While I can select the manual transmission option in the coding assistant, I receive an error message when confirming the coding: "Coding not accepted! Error 31: Invalid value range!"
| Description: |
| File size: |
17.09 KB |
| Viewed: |
1182 times |
| Description: |
| File size: |
37.59 KB |
| Viewed: |
1667 times |
Translated on 08-07-2026, 21:10.
Joined: 04/12/2002 Posts: 18093 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
04-06-2021, 20:26 Subject: Engine control unit cannot be coded for manual transmission |
Is this engine control unit with this VAG part number available in cars with manual transmissions?
Translated on 08-07-2026, 21:11.
Profile PM WWW Garage |
Dracula
04-06-2021, 20:53 Subject: Engine control unit cannot be coded for manual transmission |
Hello Rainer,
Unfortunately, I can't tell you that. I didn't realize that the transmission of the donor vehicle was so important; I would need to do some research first.
Translated on 08-07-2026, 21:12.
Dracula
dieselschrauber likes this. |
04-06-2021, 22:17 Subject: Engine control unit cannot be coded for manual transmission |
It appears that the software version was only available with DSG.
Translated on 08-07-2026, 21:13.
Dracula
dieselschrauber, Herbert and Turbinchen likes this. |
05-06-2021, 16:56 Subject: Engine control unit cannot be coded for manual transmission |
With software version 03L 906 018 RK, the problem is solved.
Translated on 08-07-2026, 21:14.
david16v
03-01-2022, 11:50 Subject: Engine control unit cannot be coded for manual transmission |
...I'll chime in here.
After installing a used engine control unit, I'm now experiencing a similar problem. The coding in the engine control unit is 00000000. When I try to change the coding value (regardless of the value), I always get the message "Invalid value range."
I'm also experiencing similar issues with the ABS and parking brake control units, which are also incorrectly coded.
David.
Translated on 08-07-2026, 21:15.
Dracula
03-01-2022, 15:12 Subject: Engine control unit cannot be coded for manual transmission |
Hello David,
You need to check which coding options are allowed for the software version of your control unit, meaning which transmissions/engine features, etc., were originally available. You can only code what was originally offered. If you need a different coding, the easiest solution would be to purchase a control unit with the appropriate software version. The last two letters are crucial.
Translated on 08-07-2026, 21:17.
david16v
03-01-2022, 16:57 Subject: Engine control unit cannot be coded for manual transmission |
The problem is twofold: firstly, there is no more "original" control unit available, and secondly, the coding cannot be changed at all. For example, I cannot even change the coding to indicate that an "airbag is installed"...
Translated on 08-07-2026, 21:18.
Dracula
03-01-2022, 19:08 Subject: Engine control unit cannot be coded for manual transmission |
You must enter a completely valid encoding, not just individual features.
Even if you don't have the original, you need a version with software that covers all the existing features; otherwise, it simply won't work.
