Distance Control Sensor Fault: Causes & Fixes
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
turbothomas77
Post09-07-2021, 6:53    Subject: Distance Control Sensor Fault: Causes & Fixes Quote
Hello everyone, I'm new here and already having a problem with the sensor for the automatic distance control system.
Volkswagen Golf 7 R.
After an oil cooler was installed in the workshop, requiring the removal of the front bumper with the radar sensor, the "Front Assist" system has stopped working. While the camera can be calibrated, the radar sensor displays an "access denied" error message according to the workshop.
Does anyone have any ideas for me?
Attached is the log.
Thank you.
Thomas.
Log-0707-WVWZZZAUZHW389321-57470km.txt
 File name:  Log-0707-WVWZZZAUZHW389321-57470km.txt
 File size:  26.07 KB
 Downloaded:  1103 times
Translated on 28-07-2026, 5:47.
Post09-07-2021, 7:03    Subject: Distance Control Sensor Fault: Causes & Fixes Quote
I suspect that either the additional metal from the oil cooler is affecting the radar signal (which I find unlikely unless it's relatively close to the sensor and within its field of view), or the position of the radar sensor has changed.
Can it be moved or mounted in a significantly different way?
Here's a topic about that:
https://forums.ross-tech.com/index.php?threads/15285/
In the section, you can also see the measured values of the setting. icon_idea.gif
Here's another thing: You should fix the problem with the rail pressure sensor in the car scan tool. Otherwise, you might end up stranded somewhere in the middle of nowhere due to a damaged cable, short circuit, or something similar.
Translated on 28-07-2026, 5:49.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM Error: Coolant Temperature Sensor (G2) On-Board Diagnostics (OBD)
No new posts Differential pressure sensor: Error code P2453 despite ne... Diesel Engine Technology
No new posts Air Quality Sensor Replacement: Golf 7 Error Persists Electrical Systems, Vehicle Electronics, Multimedia
No new posts automatic mirrors Diesel Engine Technology
