Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair.
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
3bAFN
Karma: +33 / -0   Thank you, like it!
Post12-07-2021, 19:10    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Hello everyone,
I have a friend's Caddy here with the 2.0 SDI BST engine that won't start.
The preheating lamp is not working.
No errors found in memory.
Measurement blocks are always labeled "n.v."
In the control unit for the dashboard module, there was a message indicating no communication with the engine control unit. I unfortunately didn't perform an auto-scan.
Is the control unit likely defective?
Translated on 08-08-2026, 21:26.
Post13-07-2021, 7:26    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Without an Autoscan, it's difficult to say much.
I don't think the engine control unit (ECU) is defective, because the diagnostic system works and there are no error codes stored.
"LG" can be translated as "Best regards" or "Sincerely". It is a common abbreviation for "Liebe GrĂŒĂŸe", which means "Warm greetings" in English.
Translated on 08-08-2026, 21:27.
3bAFN
Post15-07-2021, 14:48    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Hello, here is the requested car scan of the Caddy.
Thursday, July 15, 2021, 2:42:33 PM: 23565
VCDS – A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 20.12.0.3
Data as of: 20210211 DS322.1
www.Ross-Tech.de
Vehicle Identification Number (VIN): WV1ZZZ2KZ7X124127 License plate:
Mileage: 189,180 km. Repair order: Bernd.
Vehicle type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56 69 77
Vehicle Identification Number (VIN): WV1ZZZ2KZ7X124127. Mileage: 189,180 km.
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: unreachable 1100
03-Brake electronics -- Status: unreachable 1100.
09-Central Electrical System -- Status: Error 0010.
15-Airbag -- Status: Error 0010.
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block module -- Status: Error 0010.
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric passenger door - Status: Error 0010.
56-Radio -- Status: Error 0010.
69 followers -- Status: OK 0000
77-Phone -- Status: Error 0010.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module (ECM)
Label file: DRV\03G-906-016-BDJ.clb
Part number SW: 03G 906 016 HN, HW: 028 101 227 2.
Component: R4 2.0L EDC 7361
Operating number: WSC 35110 377 00156
VCID: 76E5888C019B30342A-8022
No error codes found.
or error codes are not supported by the control unit.
or communication errors occurred.
Address 03: Brake electronics.
unavailable
Address 09: Central Electronics; Label file: .DRV\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 AE, Hardware part number: 3C0 937 049 AE.
Component: On-board network module H52 2002.
Revision: 00H52000 Serial Number: 00000006917866
Encoding: 01884F030004100047000000000000000009FF075C0001
Operating number: WSC 35110 377 08192
VCID: 6CD1AAE44FD7FAE4CC-8038
Subsystem 1 - Part number: 2K1 955 119 C. Label file: DRV\1KX-955-119.CLB.
Part number: Wiper blade 110407 021 0501.
Encoding: 00038805
10 error codes found:
01504 - License plate illumination (X)
012 - Electrical fault in the circuit - Intermittent.
Environmental conditions:
Error status: 00101100
Error priority: 2
Error frequency: 1.
Lost Count: 153
Mileage: 189,189 km
Time: 0.
Date: 2005.09.13
Zeit: 31:63:63
one
Voltage: 12.20 V
one
one
aus
aus
aus
02394 - Lamp for front left side marker light (M1).
Umgebungsbedingungen:
Error priority: 2
FehlerhÀufigkeit: 1
Lost Count: 153
Mileage: 189,189 km
Zeitangabe: 0
Date: 2005.09.13
Time: 31:63:63
one
Voltage: 12.05 V
ein
one
text
from
aus
text
from
00834 - Signal for controlling the heated rear window.
009 - Unterbrechung/Kurzschluss nach Masse - Sporadisch
Error status: 00101001
FehlerprioritÀt: 5
Error frequency: 1.
Lost Count: 153
Kilometerstand: 189189 km
Time: 0.
Date: 2005.09.13
Time: 31:63:63
text
from
Voltage: 12.80 V
text
from
text
from
aus
aus
aus
01117 - Load signal for generator terminal DF.
008 - implausible signal - sporadic.
Error status: 00101000
Error priority: 2
FehlerhÀufigkeit: 1
Lost Count: 153
Mileage: 189,189 km
Time: 0.
Date: 2005.09.13
Time: 31:63:63
one
Spannung: 12.50 V
ein
one
text
from
aus
text
from
00532 - Power supply voltage.
001 - oberer Grenzwert ĂŒberschritten - Sporadisch
Fehlerstatus: 00100001
FehlerprioritÀt: 2
FehlerhÀufigkeit: 1
Lost Count: 153
Zeitangabe: 0
Datum: 2005.09.13
Time: 31:63:63
ein
Spannung: 16.15 V
ein
ein
aus
aus
aus
01516 - Klemme 30 links
011 - Unterbrechung - Sporadisch
Fehlerstatus: 00101011
FehlerprioritÀt: 1
FehlerhÀufigkeit: 1
VerlernzÀhler: 153
Zeitangabe: 0
Datum: 2005.09.13
Zeit: 31:63:63
aus
Spannung: 12.75 V
aus
ein
aus
aus
aus
01314 - MotorsteuergerÀt
004 - kein Signal/Kommunikation
Fehlerstatus: 01100100
FehlerprioritÀt: 2
FehlerhÀufigkeit: 10
VerlernzÀhler: 113
Time: 0.
Datum: 2005.09.13
Zeit: 31:63:63
ein
Voltage: 12.30 V
ein
ein
aus
aus
aus
00447 - FunktionseinschrĂ€nkung durch Überspannung
FehlerprioritÀt: 4
FehlerhÀufigkeit: 2
VerlernzÀhler: 153
Time: 0.
Date: 2005.09.13
Zeit: 31:63:63
ein
Voltage: 16.45 V
ein
ein
aus
text
from
aus
02195 - Regler fĂŒr Beleuchtung - Schalter und Instrumente (E20)
006 - Kurzschluss nach Plus - Sporadisch
Error status: 00100110
FehlerprioritÀt: 5
FehlerhÀufigkeit: 11
Lost Count: 153
Mileage: 189,189 km
Zeitangabe: 0
Datum: 2005.09.13
Time: 31:63:63
ein
Spannung: 12.10 V
one
one
aus
aus
aus
00927 - Terminal 30, right side.
011 - Interruption - Occasional/Sporadic.
Error priority: 1.
Error frequency: 1.
Lost Count: 153
Mileage: 189,189 km
Time: 0.
Date: 2005.09.13
Time: 31:63:63
text
from
Voltage: 12.75 V
text
from
one
text
from
text
from
text
from
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW52.lbl
Part number SW: 6Q0 909 605 AH, Part number HW: 6Q0 909 605 AH.
Part number: 09 AIRBAG VW52 023 2400.
Revision: 04023000 Serial Number: 0037TD0DWFK3
Encoding: 0012345
VCID: 7DF797A024AD636C6B-8028
"One error found:"
002 - Lower limit exceeded - Intermittent.
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Steering column module 636 0070.
Encoding: 0000011
VCID: 0009EE54535F0E8400-8054
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number SW: 1T0 920 863 A, Hardware part number: 1T0 920 863 A.
Component: COMBINATION INSTRUMENT VDD 1610
Revision: V0003000 Serial Number: VWZ7Z0G7069003
Encoding: 0016101
Operating Number: WSC 02695 002 1048576
VCID: 326D749CAD736C14C6-8066
3 error codes found:
01314 - Engine Control Unit (ECU)
004 - No signal/communication.
Error status: 01100100
Error priority: 2
Error frequency: 47
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 02:40:26
00446 - Function impairment due to undervoltage.
Error status: 00100010
Error priority: 2
Error frequency: 2.
Lost Count: 153
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 22:13:13
01316 - Brake control unit.
Error priority: 2
Error frequency: 3
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 10:22:56 PM
Address 19: Diagnostic interface
Label file: .DRV\1K0-907-530-V2.clb
Part number SW: 1K0 907 530 K, HW: 1K0 907 951.
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 070407F2001975
Encoding: 1D0F41C007007400
VCID: 2F6B7DE8BE4141FCA9-807A
Two error codes found:
Error priority: 2
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 06:15:28
Error priority: 2
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 22:22:57
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Component: IMMO Part Number: 1610
Operating number: WSC 02695 002 1048576
Address 42: Door electric driver. Label file: .DRV\1K0-959-701-MIN3.clb
Part number SW: 1T0 959 701 D, HW: 1T0 959 701 D.
Component: Door seal 005 0955
Encoding: 0000048
VCID: 387946B44B0F8644F8-806C
Address 46: Comfort System; Label file: .DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 CP
Component: KSG 0401
Encoding: 80890C087F2D8405484A036010C0
Operating number: WSC 73113 123 62133
Subsystem 1 - Component: Sounder (not mounted)
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE (not mounted)
01517 - Trailer detection control unit (J345).
004 - No signal/communication - Intermittent.
00668 - Voltage at terminal 30.
001 - Upper limit exceeded - Intermittent.
01312 - Data bus for drive system.
013 - Please read the error memory.
Address 52: Power door lock, front passenger side. Label file: .DRV\1K0-959-702-MIN3.clb
Part number SW: 1T0 959 702 D, HW: 1T0 959 702 D.
Component: Door seal 005 0929
Encoding: 0000048
VCID: 397F43B070059F4C07-806C
"One error found:"
01812 - Power supply voltage for door control unit, passenger side (J387).
Address 56: Radio (J0503) Label file: .DRV\5M0-035-1xx-56.clb
Part number SW: 2K0 035 156, HW: 2K0 035 156.
Component: Radio 008 0007
Revision: R0008000 Serial Number: VWZAZ1G4707804
Encoding: 0000020202
VCID: 61CFCBD07815A78C6F-8034
"One error found:"
00856 - Antenna; for the radio.
011 - Interruption.
Error status: 01101011
Error priority: 5.
Error frequency: 1.
Lost Count: 153
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 00:00:10
Address 69: Trailer.
unavailable
Address 77: Telephone
Label file: DRV\3C0-035-729.lbl
Part number SW: 3C0 035 729 F, HW: 3C0 035 729 F.
Component: Telephone 7009
Revision: 00012000 Serial Number: 0000000887592
Encoding: 0016021
Operating number: WSC 73113 123 87122
VCID: 264598CC91BB00B45A-8072
000 - - - Sporadic
Error status: 00100000
Error priority: 3
Error frequency: 2.
Lost Count: 153
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 22:13:10
00992 - Consumer shutdown active.
000 - - - Sporadic
Error priority: 3
Error frequency: 4
Lost Count: 153
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 17:18:38
End----------------------------(Duration: 01:29)-----------------------------
Translated on 09-08-2026, 0:09.
Post15-07-2021, 19:31    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
The voltage fluctuations in your vehicle's electrical system are erratic. I would start by addressing that issue. Furthermore, there are several indications of problems within the vehicle's electrical system or wiring issues.
Just take a look at your car's diagnostic scan.
Translated on 09-08-2026, 0:10.
3bAFN
Post15-07-2021, 20:06    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
I am concerned that in some tax devices, the limit of the supply voltage is being exceeded, while in others it is falling below the required level.
I cleared all the error codes, turned off the ignition, briefly interrupted the power, and then turned it back on to immediately perform this car scan.
Translated on 09-08-2026, 0:11.
Post16-07-2021, 8:10    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
... would first check if the connections at the battery are securely fastened and, during a start-up attempt, record the on-board voltage in the engine control unit. icon_idea.gif
3bAFN
Post16-07-2021, 22:49    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
All the connections have been checked and found to be in good working order.
I would like to read the voltage of the engine control unit, but that is not possible. For illustrative purposes, I have attached two photos showing what it looks like.
 File size:  4.13 MB
 Viewed:  844 times
 File size:  5.34 MB
 Viewed:  684 times
Translated on 09-08-2026, 0:12.
3bAFN
Post16-07-2021, 22:51    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Here's another recent car scan with a new battery.
15-Airbag -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
77-Phone -- Status: OK 0000
unavailable
Encoding: 00038805
"One error found:"
Error priority: 2
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2005.09.13
Time: 31:63:63
one
Voltage: 12.30 V
one
one
text
from
text
from
text
from
Address 15: Airbag
Encoding: 0012345
Encoding: 0000011
Encoding: 0016101
Error priority: 2
Error frequency: 2.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 09:21:28
Error priority: 2
Error frequency: 2.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 09:21:28
Error priority: 2
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 09:21:30
Error priority: 2
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 09:21:30
Encoding: 0000048
Component: KSG 0401
"One error found:"
Encoding: 0000048
"One error found:"
011 - Interruption.
Error priority: 5.
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 09:21:46
unavailable
Encoding: 0016021
Translated on 09-08-2026, 0:39.
Dagomanu
Karma: +55 / -0   Thank you, like it!
dieselschrauber likes this.
Post16-07-2021, 23:21    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Hello, have you also checked the grounding points in the engine compartment? They might be corroded. There's a possibility that the electrical box is oxidized or has water ingress.
Dago
Translated on 09-08-2026, 1:10.
Post17-07-2021, 11:59    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
It is very unusual for nothing to be displayed in the extended measurement data blocks.
Have you ever looked at the tuning data stored in the engine control unit, or even other measured values? Not all of them provide meaningful information.
Translated on 09-08-2026, 1:11.
3bAFN
Post17-07-2021, 18:17    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
The control unit is equipped with the original data set.
I've tested all the measurement values, but it always displays "n.v." (not available). I know that with the Caddy 2K, you can also check additional information under the normal measurement value blocks, but that's not possible here because those sections are grayed out.
Post18-07-2021, 10:34    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
I've tested all the measurement values, and it always displays "n.v."
. I know that with the Caddy 2K, you can also look at additional information under the normal measurement value blocks, but that's not possible here because it's grayed out.}
"Always on" is not normal. Is there really power supplied to all the supply voltage pins of the engine control unit? It seems more like a kind of "control unit overrun" rather than normal operation.
Translated on 09-08-2026, 1:13.
3bAFN
Post21-07-2021, 20:17    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Okay, I've checked the power supply now and I think everything is fine.
When the ignition is turned on, pins 3, 5, 6, and 18 are powered with 12V.
Translated on 09-08-2026, 1:14.
Post21-07-2021, 20:43    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Based on the numerous "not reachable" entries, I suspect there may be wiring harness issues with the CAN drive.
3bAFN
Post21-07-2021, 21:23    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
Since the brake electronics were also inaccessible, I checked the power supply there and found it to be working correctly.
The ABS control unit has been replaced, and all the brake errors have disappeared.
Therefore, here is a recent car scan.
03-Brake electronics -- Status: Error 0010.
46-Comfort System -- Status: OK 0000
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK70.lbl
Part number: 1K0 907 379 P
Part number: ASR FRONT MK70 0105.
Encoding: 0017106
Operating number: WSC 01279 785 00200
VCID: 3F8B2DA86E21B17C39-806A
"One error found:"
Subsystem 1 - Part number: 2K1 955 119 C Label file: DRV\1KX-955-119.CLB
Encoding: 00038805
"One error found:"
Error priority: 2
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2005.09.13
Time: 31:63:63
one
Voltage: 12.05 V
one
one
text
from
text
from
text
from
Address 15: Airbag
Encoding: 0012345
Encoding: 0000011
Encoding: 0016101
"One error found:"
Error priority: 2
Error frequency: 2.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 08:14:57
"One error found:"
Error priority: 2
Error frequency: 1.
Lost Count: 113
Mileage: 189,189 km
Time: 0.
Date: 2000.00.00
Time: 08:14:58
Encoding: 0000048
Component: KSG 0401
Encoding: 0000048
"One error found:"
011 - Interruption.
Error priority: 5.
Error frequency: 1.
Lost Count: 113
Mileage: 0 km
Time: 0.
unavailable
Encoding: 0016021
End----------------------------(Duration: 01:25)-----------------------------
Shouldn't the engine at least start or have the preheating light illuminate, even if there's a problem with the wiring harness of the CAN drive?
Does the engine control unit still communicate via the K-line in vehicles with the 2K system?
Translated on 09-08-2026, 1:39.
Dagomanu
Post22-07-2021, 0:21    Subject: Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Quote
The CAN comfort system can communicate via a single wire even with a cable problem on one side. The CAN driver, for safety reasons, cannot. The K-line was originally intended only for data related to emissions. Unfortunately, I cannot say exactly how many measurement values could be achieved using it.
Was attempted to give the vehicle a jump start with reversed polarity by chance?
Dago
Translated on 09-08-2026, 2:09.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heckklappe VW Caddy Mj.2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Are Caddy TDIs with 105 hp and 75 hp identical (except fo... Diesel Engine Technology
No new posts KM-Stand Auslesen aus SteuergerÀt Vw Caddy /neues Modell On-Board Diagnostics (OBD)
No new posts SteuergerÀt defekt was tun ? On-Board Diagnostics (OBD)
No new posts Faulty T4 engine control unit, 2.5 TDI ACV On-Board Diagnostics (OBD)
