Fuel Injection Amount Idle / Metering Device
mk20vt
Post18-08-2021, 0:26    Subject: Fuel Injection Amount Idle / Metering Device Quote
Hello everyone,
Due to an inaccuracy in my AFN code, I was overly enthusiastic and replaced the lower seal on the quantity control unit. I loosened the three screws, marked everything, and reassembled it. However, I didn't log the actual injection amount at idle before the repair using VCDS. The engine runs smoothly, starts well, and has normal fuel consumption, but I feel like it produces slightly more soot than before. Since I found many different values in searches and forums that range from 3 to 5.5 mg/stroke, I wanted to ask if anyone here knows the exact values for the AFN (warm engine, without any electrical load).
Thank you very much.
Translated on 24-08-2026, 18:43.
Post18-08-2021, 21:58    Subject: Fuel Injection Amount Idle / Metering Device Quote
4.75 mg per dose.
Have fun setting it up! X
See also:
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 24-08-2026, 18:45.
mk20vt
dieselschrauber likes this.
Post19-08-2021, 22:44    Subject: Fuel Injection Amount Idle / Metering Device Quote
Hello.
Thank you for the precise information! I actually adjusted the fuel injection pump based solely on soot emissions and driving behavior to 4.6-4.8 mg/stroke. Before that, it was set at 3.8 mg/stroke, but it produced excessive soot, and anything above 6 mg/stroke results in a poor warm start.
Thank you again for the information; I can just leave the pump as it is then!
Translated on 24-08-2026, 18:46.
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Engine Knocking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2.5 TDI: Fuel Injector Calibration Issues Diesel Engine Technology
No new posts Faulty Metering Valve? Get it Fixed! Diesel Engine Technology
No new posts TDI Smoke: A4 1.9 (AFN) - What's the Cause? Diesel Engine Technology
No new posts Adjustment aid for the quantity setting device on the VP37 Diesel Engine Technology
