2.0 TDI Timing Belt Replacement - High-Pressure Pump Misaligned/Twisted
ChrisGo3009
Post26-08-2021, 17:49    Subject: 2.0 TDI Timing Belt Replacement - High-Pressure Pump Misaligned/Twisted Quote
Hi there,
I'm new to this forum and would like to introduce myself briefly.
Living in the Geestland region near Bremerhaven, I am 38 years old and a qualified mechanical engineer.
Passionate mechanic, mainly working on motorcycles (For street use: Aprilia Tuono 1100, For track use: Aprilia RSV Mille RP), if anyone is interested icon_wink.gif.
To get to the main point, I attempted to replace the timing belt on my Audi A4 B8 2.0 TDI.
So far, so good. The timing belt is off – the crankshaft and camshaft are secured, but unfortunately, the high-pressure pump isn't.
Unfortunately, while clumsily removing the timing belt, the hub of the high-pressure pump was rotated approximately 30 degrees further.
Now, the crucial question: How do I proceed from here?
Thank you in advance for your help!
BG.
Chris.
 File size:  3.81 MB
 Viewed:  8637 times
Translated on 18-07-2026, 19:25.
Karma: +1344 / -0   Thank you, like it!
ChrisGo3009 likes this.
Post26-08-2021, 20:49    Subject: 2.0 TDI Timing Belt Replacement - High-Pressure Pump Misaligned/Twisted Quote
Hi there,
What is preventing you from repositioning the high-pressure pump and sealing it?
Translated on 18-07-2026, 19:27.
ChrisGo3009
Post26-08-2021, 21:04    Subject: 2.0 TDI Timing Belt Replacement - High-Pressure Pump Misaligned/Twisted Quote
Hi Herbert,
Thanks in advance for your reply!
I didn't dare to rotate it 30 degrees counterclockwise because I felt resistance when I tried to do so slightly.
I'm not sure about the translation regarding whether it should be 360° or now only 330° clockwise, due to the gear ratio of the hydraulic pump.
I was thinking about a 2:1 ratio between the crankshaft and camshaft.
Or would it work if I just rotate it one turn clockwise?
BG.
Chris.
Translated on 18-07-2026, 19:28.
dieselschrauber and ChrisGo3009 likes this.
Post26-08-2021, 21:20    Subject: 2.0 TDI Timing Belt Replacement - High-Pressure Pump Misaligned/Twisted Quote
Ideally, both options should work. The high-pressure pump runs synchronously with the crankshaft, so the 360° (or 330° in your case) timing will never be wrong.
Translated on 18-07-2026, 19:29.
ChrisGo3009
Post26-08-2021, 21:29    Subject: 2.0 TDI Timing Belt Replacement - High-Pressure Pump Misaligned/Twisted Quote
Great, that's the information I needed.
Tomorrow, the "timing belt" operation will continue calmly icon_smile_thumb_up.gif.
BG.
Chris.
Translated on 18-07-2026, 19:30.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts VP37 High-Pressure Pump Replacement Diesel Engine Technology
No new posts Low rail pressure. - Defective high-pressure pump? Gasoline Engine Technology
No new posts High-pressure pump screw sheared off, need help Diesel Engine Technology
No new posts High-Pressure Pump Timing: Why It Matters Diesel Engine Technology
