AEL Control Unit and GRA
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
benschke
Karma: +9 / -0   Thank you, like it!
2015 Volkswagen Golf
Post10-10-2021, 15:08    Subject: AEL Control Unit and GRA Quote
I upgraded the steering column switch with the GRA lever on my Audi A6 C4 2.5L TDI and routed the corresponding cables to the control unit and fuse box according to the relevant instructions.
So far, so good.
Unfortunately, it seems my control unit is not able to execute the GRA activation.
Part number.
AUDI 4A0 907 401 P
(Date: 04/26/97) I can gladly provide further details if needed.
Vehicle manufactured in July 1997.
Motor AEL
6-speed manual transmission.
without MFA.
The automatic error diagnosis shows only 1 error:
Code:
Adresse 17: Schalttafeleinsatz        Labeldatei: DRV\4Ax-919-03x-17.lbl
   Teilenummer: 4A1 919 033 HG
   Bauteil: C4-KOMBIINSTRUMENT  D20
   Codierung: 00050
   Betriebsnr.: WSC 11111
   VCID: 6E8430F32985287B6DF-1DFC
Keine Fehlercodes gefunden.
  oder Fehlercodes werden vom Steuergerät nicht unterstützt
  oder Kommunikationsfehler aufgetreten"
When entering 11463 using the login code, as described here, nothing happens.
When I try to achieve anything related to "coding" using VCDS, I receive a message indicating that coding is not possible in that control unit.
"The measurement block displays 'Data not available for block 006'." For a moment, it displays the corresponding values, but then the text turns red again.
--> Pedal switches are functioning (pressing the clutch pedal shows 100, pressing the brake pedal shows 011).
Did I miss a step so that it can take over the GRA activation?
Does my control unit not work at all?
Do I need an additional control unit?
Which engine control units (ECUs) are known to be functional?
Do you have any suggestions on where else I can look or ask?
Thank you!
1997 Audi A6 Avant, 2,5l TDI (Motor AEL)
2015 VW Golf Variant, 2,0l TDI (Motor CRLB)
1965 VW 1200 (Exportmodell)
Post10-10-2021, 15:48    Subject: AEL Control Unit and GRA Quote
Please post the entire Autoscan.
benschke
Post10-10-2021, 16:22    Subject: AEL Control Unit and GRA Quote
Sunday, October 10, 2021, 4:20:43 PM: 08912
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 21.3.0.0 HEX-V2 CB: 0.4555.4
Data as of: 20210508 DS325.1
http://shop.dieselschrauber.org/en
Vehicle type: 4A - Audi 100/A6 C4 (1992 > 1997)
Scan: 01 02 03 08 15 17 25 35
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: DRV\046-907-401-AEL.lbl
Part number: 4A0 907 401 P
Component: 2.5L R5/2VT EDC HS D30
Encoding: 00000
Operating Number: WSC 00000
VCID: 2A0CFCE3D5ED045BF17-4A66
No error codes found.
Readiness: Not Available.
Address 03: Brake Electronics Label file: DRV\4D0-907-379-ABS.lbl
Part number: 4D0 907 379 D
Part: ABS BOSCH 5, 4174
Operating number: BB 34174
VCID: 2F3AEDF7EE0F6173269-51F2
Address 08: Climate Control/Heating Module. Label file: 4A0-820-043.lbl
Part number: 4A0 820 043 K.
Component: Climate Control System, Fully Automatic D05.
Encoding: 00053
Operating number: WSC 02324
VCID: 211E1BCFA8DBC703A0D-2586
2 error codes found:
00799 - Coolant temperature sensor (G110)
30-10 - Interruption / Short circuit after positive voltage - Occasional.
00603 - Actuator motor for footwell/defrost flap (V85)
41-00 - Blocked or Unpowered.
Address 15: Airbag
Label file: DRV\8A0-959-655.lbl
Part number: 8A0 959 655 C.
Component: Airbag, V, AUDI D01.
Encoding: 01022
VCID: 3332E18702274593421-52D0
Address 17: Control panel module
Label file: DRV\4Ax-919-03x-17.lbl
Part number: 4A1 919 033 HG.
Component: C4 COMBINATION INSTRUMENT D20.
Encoding: 00050
or error codes are not supported by the control unit.
or communication errors occurred.
Address 25: Immobilizer
Label file: DRV\4A0-953-234.lbl
Part number: 4A0 953 234 F
Part number: IMMO AUZ9Z0V4171375 D77
Encoding: 00000
VCID: 25160FDFBCF32B23DC5-50D0
Address 35: Central locking
Label file: . DRV\8D0-862-257.clb
Part number: 8LO 862 257 E.
Component: Central locking pump D03
Encoding: 00032
Operating number: WSC 65535
VCID: 56F47813B11570BB85F-4EEA
End -- (Duration: 01:14, Battery voltage start/end: 12.5V/12.5V). VIgn 0.0V)----
Post10-10-2021, 16:36    Subject: AEL Control Unit and GRA Quote
Have you checked to see if you have a "very old" vehicle?
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
I'm sorry, but I can't translate that because it appears to be a special character or code rather than text. Please provide the actual text you would like me to translate.
benschke
Post10-10-2021, 16:47    Subject: AEL Control Unit and GRA Quote
Yes, I also tested the code for "very old". No response.
Post10-10-2021, 17:03    Subject: AEL Control Unit and GRA Quote
There are no other control units involved besides the engine control unit.
Why are you writing about code? Nothing is being encoded here.
Just enter your login.
benschke
Post10-10-2021, 17:11    Subject: AEL Control Unit and GRA Quote
I am writing code because it says "Login Code" here icon_smile.gif.
Post10-10-2021, 17:59    Subject: AEL Control Unit and GRA Quote
Okay, my thought was that it wasn't entered during the coding process...
Can you also see the GRA status in the bits?
benschke
dieselschrauber likes this.
Post10-10-2021, 18:48    Subject: AEL Control Unit and GRA Quote
The tip about the GRA bits being on/off was a good one.
I also found this and noticed that in measurement block 006, the non-activated GRA displays "255" in the 4th position. Field of MWB 006:
https://t4-wiki.de/wiki/Messwertblock
Okay, in my case, it's still "disabled," and the value 255 appeared in the fourth position. Field.
Okay, so I entered "login for GRA 'activated'" and then it was on the 4th [line/step/screen]. Field "0.0".
According to this, the MSG at least accepts the login code.
So, the problem probably isn't in the MSG (presumably a module), but rather in the hardware/steering column switch, or something similar. Wiring? (I actually checked it with a multimeter before installation.)
In field 3 of MWB 006, "GRA Switch Positions," the values are not changing, no matter which button I press. It always displays "000000" in that field.
What makes me suspicious is the red text (see video). Is that normal?
AEL Control Unit and GRA - trim.B19BE87F-83B2-4CDB-9EB1-403AFD477DC3.MOV
 File size:  6.68 MB
 Viewed:  495 times
benschke likes this.
Post10-10-2021, 19:49    Subject: AEL Control Unit and GRA Quote
Okay, that's great already!
GRA, does the lever require +12V, are the connections properly inserted?
Besides that, my original GRA (gear selector) lever on my A3 8P broke after a very short time; the GRA stopped working. So, the lever itself can be another potential source of error.
I then set it to "always on" because you can always turn it off if you want.
benschke
Post22-10-2021, 15:56    Subject: Error found. Problem solved Quote
Hello Rainer,
I've checked everything again and found that the cable to fuse 64 was not wired correctly.
After I corrected that, everything worked.
Thank you for your help.
Cruise control is now working.
The issue with the red text in MWB 006 is still present.
Is that normal?
Greetings.
Post22-10-2021, 16:11    Subject: AEL Control Unit and GRA Quote
Thank you for your feedback!
If the measured data appears six times in some cases and not in others, it could indicate that the bit rates in the communication between the ECU and the interface are incorrect. This can happen when quartz crystals age...
If it works now, then it's fine.
Rainer
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Central locking control unit in the 8D2 On-Board Diagnostics (OBD)
No new posts Steuergerät?!?! Diesel Engine Technology
No new posts Steuergerät und LMM On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
