Audi A6 C6, right brake light
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
vag-driver
Post26-10-2021, 10:16    Subject: Audi A6 C6, right brake light Quote
"The following message repeatedly appears on this pre-facelift model:"
Address 46: Comfort System
Label file: 4F0-910-289.lbl
Part number SW: 4F0 910 289 F, HW: 4F0 907 289 F.
Component: Comfort Device H22 0170.
Revision: 01700022 Serial number: 01041644010000
Encoding: 0131205
Operating number: WSC 02335 758 00200
VCID: 2D573FB1B45A87E358-8078
"1 error found:"
00988 - Lamp for right brake light (M10).
009 - Intermittent short circuit to ground.
Environmental conditions:
Error status: 00101001
Error priority: 3.
Error frequency: 3
Lost Count: 197
Mileage: 322,557 km
Time: 0
Date: 2021.10.05
Time: 17:07:21
This can be deleted, but it will reappear. However, the brake light is working. Is this a known issue? I suspect the circuit board is failing.
Andreas
Duese
Post28-10-2021, 7:31    Subject: Audi A6 C6, right brake light Quote
The original taillights (without LED) are prone to water leaks.
The contacts of the bulbs can oxidize, but a tiny dab of copper paste on the bulb's contact can help. Don't drip or splatter, or there will be a short circuit.
And sometimes, simply replacing the bulb is enough. Sometimes, the filament isn't properly secured to the base, which can cause the bulb to work intermittently.
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
No new posts Seat Leon, 2012 model, LED brake light flickering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Pulls to One Side: Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Backup fuse for trailer brake light. Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3C with brake light functioning as a taillight Upload
No new posts Passat 3BG: Brake Light Switch & Engine Problem On-Board Diagnostics (OBD)
No new posts Tire Noise Front Right? Transmission, Chassis, Body & Interior
