Replace Spark Plugs: DIY Guide & Tips
vag-driver
Post21-11-2021, 16:48    Subject: Replace Spark Plugs: DIY Guide & Tips Quote
How do you handle replacing spark plugs? In my case, one out of six is faulty. All of them were replaced about 5 years ago and after approximately 110,000 kilometers (or miles).
Should I just replace the defective one, or should I replace them all at once? My gut feeling is that I should replace them all.
Andreas
Translated on 22-08-2026, 22:55.
Post21-11-2021, 17:17    Subject: Replace Spark Plugs: DIY Guide & Tips Quote
I would replace them all when the engine is hot.
However, it's unlikely that a glow plug will fail unless absolutely necessary; typically, this happens after around 150,000 kilometers.
Translated on 22-08-2026, 22:56.
vag-driver
dieselschrauber likes this.
Post21-11-2021, 17:58    Subject: Replace Spark Plugs: DIY Guide & Tips Quote
Yes, in this case. And I installed Beru spark plugs.
Andreas
Translated on 22-08-2026, 22:57.
Post22-11-2021, 6:51    Subject: Replace Spark Plugs: DIY Guide & Tips Quote
If they all come loose, remove them and install new ones coated with ceramic paste.
It makes sense to periodically expand and clean these components each year, so that the threads and shafts don't become clogged with oil residue, and to avoid unnecessary problems when disassembly is actually required.
vag-driver
Post22-11-2021, 11:12    Subject: Replace Spark Plugs: DIY Guide & Tips Quote
Rüdi wrote:
If all of them can be removed, take them out and install new ones coated with ceramic paste.
If I'm not mistaken, I already used ceramic paste to install them back then.
Andreas
Translated on 22-08-2026, 22:58.
Post02-12-2021, 22:18    Subject: Replace Spark Plugs: DIY Guide & Tips Quote
Rüdi wrote:
It makes sense to expand and clean these annually so that the threads and shaft do not become clogged with oil residue, and to avoid unnecessary problems during removal when it is truly necessary.
It is important to replace a faulty glow plug quickly, before it becomes stuck in the cylinder head due to carbon buildup.
Also very important: Expansion of the cooling system when the engine is running hot!
Translated on 22-08-2026, 22:59.
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
No new posts Glow Plug Replacement Audi A6 C4 AEL Diesel Engine Technology
No new posts Spark plug question Diesel Engine Technology
No new posts Glow plug firing duration Diesel Engine Technology
