A6 4G 3.0 TDI: Throttle Valve Calibration Guide
schrupf
Post04-12-2021, 19:42    Subject: A6 4G 3.0 TDI: Throttle Valve Calibration Guide Quote
After the engine check light illuminated, I read a fault code of 9129, which indicates that the throttle valve is stuck in the closed position.
After the error is cleared, it reappears after a few hundred kilometers.
Now I've bought the intake manifold flap and the throttle valve.
Now I want to install them, but I can't find the option in the basic settings that allows me to calibrate them.
Where can I find this option on the VCDS software?
Translated on 12-08-2026, 4:32.
Post04-12-2021, 20:37    Subject: A6 4G 3.0 TDI: Throttle Valve Calibration Guide Quote
How do you know that it needs to be calibrated?
Have you ever watched "Security Access"?
Autoscan?
Translated on 12-08-2026, 4:33.
schrupf
Post04-12-2021, 21:34    Subject: A6 4G 3.0 TDI: Throttle Valve Calibration Guide Quote
It clearly states on the packaging that it needs to be paired/configured.
It's also written on the Pierburg website.
Translated on 12-08-2026, 4:34.
schrupf
Post04-12-2021, 23:55    Subject: A6 4G 3.0 TDI: Throttle Valve Calibration Guide Quote
When I navigate to the security code field, the security code that I would need to enter is not displayed, unlike with other control units.
I found a code, T5 T6 27971, and I entered it, and it was accepted.
But even then, I couldn't find anything in the basic settings.
Post05-12-2021, 9:55    Subject: A6 4G 3.0 TDI: Throttle Valve Calibration Guide Quote
For various applications, there is a specific device from the VAG group. The electric actuators for the turbocharger should also be affected.
Intake manifold flap & throttle valve: Pictures?
Autoscan?
Translated on 12-08-2026, 4:35.
schrupf
dieselschrauber likes this.
Post05-12-2021, 22:06    Subject: A6 4G 3.0 TDI: Throttle Valve Calibration Guide Quote
The control elements of the turbocharger can be readjusted; this option is available.
Attached are the Autoscan results and images of the parts.
 File size:  2.44 MB
 Viewed:  407 times
 File size:  2.62 MB
 Viewed:  503 times
 File size:  2.2 MB
 Viewed:  430 times
 File size:  3.31 MB
 Viewed:  544 times
Log-FW RX 1-WAUZZZ4G0CN136593-143631km.txt
 File name:  Log-FW RX 1-WAUZZZ4G0CN136593-143631km.txt
 File size:  27.37 KB
 Downloaded:  360 times
Translated on 12-08-2026, 4:36.
No new posts P3135 - Airflow Control Valve: Exceeds Limit. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 3.0 Biturbo P0087 - Insufficient fuel rail pressure Diesel Engine Technology
No new posts Boost Pressure Too High Audi A4 8E 2.0 TDI Diesel Engine Technology
No new posts BLS intake flap Upload
No new posts Throttle valve 2 for 3.0 V6 TDI Diesel Engine Technology
