jan__1104
Joined: 10/29/2021 Posts: 4 Karma: +0 / -0 Location: Wetzlar 2007 Audi A4 Avant Free account, no CAN development support
17-11-2021, 10:05 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* New Water Pump (recommended)
* New Tensioner Pulley (recommended)
* Timing Belt Tension Gauge
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Jack and Jack Stands
* Drain Pan
* Coolant
* Timing Belt Alignment Tool (optional, but highly recommended)
**Safety Precautions:**
* Disconnect the negative battery terminal before starting any work.
* Work in a well-ventilated area.
* Wear safety glasses and gloves.
* Dispose of used coolant properly.
**Procedure:**
1. **Preparation:**
* Park the vehicle on a level surface.
* Allow the engine to cool completely.
* Disconnect the negative battery terminal.
* Drain the coolant from the radiator and engine block.
2. **Removal:**
* Remove the accessory belts (alternator, power steering, A/C).
* Remove the drive belts.
Hey tinkerers,
I have a question. The timing chain (specifically, the "Trieb B" component) broke at 156,000 km, and I didn't notice it. I thought it was a problem with the fuel pump. However, after I realized it was the timing chain, I tried to start the engine a few more times. As a result, it had wrapped itself around the drive D and had therefore flown apart into pieces.
My first question is, is it still worth switching? And if so, how does one adjust the timing chain?
My second question is whether the valves have been affected in any way. (According to my opinion, no, because there was no camshaft running alone.) Since one side has the vacuum pump running and the other has the HD pump.
VEHICLE:
Brand: Audi
Art : Avant
Model: A4 B7 (8ED)
Year of Manufacture: 2007
Engine Code: ASB
| Description: |
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
| File size: |
200.73 KB |
| Viewed: |
3801 times |
Profile PM Garage |
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
Herbert likes this. |
17-11-2021, 21:59 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
Unfortunately, it's the case that in every position of the camshaft, there is at least one cylinder with open valves.
When the crankshaft then makes one revolution, it will definitely make a noise.
Hi, Rainer
Profile PM WWW Garage |
matthiasTDI96 Profi-Schrauber
dieselschrauber and Herbert likes this. |
18-11-2021, 8:31 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
Honestly, I don't think it's worth it. Just remove the affected part and check the valves; there's probably one that's out of contact. If, against all odds, everything is okay, you can figure out the chain issue then. They should all be replaced. There must be a comprehensive repair manual from Erwin* that answers all questions.
I am, however, honestly concerned that at 14 years of age, the individual player's value must be higher than the current market value in order to achieve this.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
22-11-2021, 6:56 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
ASB --> Gasoline engine?
If so, organize a used engine, replace everything, and install it. This would be my option, provided the A4 isn't taken away from the previous Opel owner soon.
Profile PM Garage |
vag-driver Profi-Schrauber
22-11-2021, 14:38 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
Rüdi wrote: | ASB --> Gasoline engine?
ASB is the V6 diesel.
Andreas
jan__1104
23-11-2021, 21:53 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
Remove the right cylinder head. (viewed from the front)
The 1.2 cylinder looks good. The 3 has attached
therefore, the levers above are broken but the valves are
look good so far.
Regarding the timing chain:
Shafts B and D have broken and need to be replaced.
Axles A and C still look good.
2 gears are misaligned and one gear has missing teeth.
I'm really amazed that it still looks so good!
PS: I've read that the right timing chain is prone to breaking.
and that's why Audi designed the engine so that you can
the right side in the closed state is interchangeable
is. And thus, the right side is much more robust and
Designed for durability, so that it can withstand such things.
can hold.
Best regards
Jan Pohl
| Description: |
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
| File size: |
609.16 KB |
| Viewed: |
1007 times |
| Description: |
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
| File size: |
492.52 KB |
| Viewed: |
1165 times |
| Description: |
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
| File size: |
448.47 KB |
| Viewed: |
675 times |
Profile PM Garage |
dieselschrauber likes this. |
23-11-2021, 22:56 Subject: What is your plan? |
What is your plan?
Andreas
Herbert Profi-Schrauber
23-11-2021, 23:11 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
jan__1104 wrote: |
can hold.
Jan Pohl |
Therefore, the connecting rods on this side are also thicker, the camshafts are stronger, and the pistons and connecting rods are also reinforced. For example, you can tell this by the heavier cylinder head and the different balance shafts.
If you're lucky, the crank mechanism and two pistons are still usable.
jan__1104
24-11-2021, 7:24 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
Get the engine running again.
1. The cylinders look good to me and I will keep them as is.
2. Cylinder head also looks good. "I will remove the valves from the 3rd cylinder and measure them to check if they are still straight."
If so, are there new chains with gears, new levers, and a new clutch because if it's already disassembled.
Profile PM Garage |
24-11-2021, 11:29 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
Even if the valves look good, it's important to remove them and inspect them, as they can be compressed, and this is not apparent when they are installed.
I would also thoroughly disassemble everything, meticulously clean all parts, and re-machine the valves. I always do this when a TDI head needs to be removed. New valve stem seals are, of course, a standard procedure.
Profile PM Garage |
jan__1104
23-12-2021, 23:15 Subject: Audi A4 B7 Timing Belt Replacement and Adjustment - DIY
**Tools Required:**
* New Timing Belt
* Socket Set
* Wrench Set
* Torque Wrench
* Pliers
* Screwdrivers
* Drain Pan
* Coolant
**Procedure:**
1. **Preparation:**
2. **Removal:**
Hi, I've now checked everything.
3 valves were misaligned, I replaced them and went to sleep.
The rest looked great.
Now I can't find anywhere that shows or explains how to properly assemble, tension, and adjust a chain tensioner.
Neither on the web nor in ELSA
Best regards
Jan Pohl
Profile PM Garage |
