Driver123 Blaumann
25-03-2022, 14:36 Subject: 1048578 Basic configuration not performed, control panel |
Hallo,hab ein kl. Problem.
Since the vcds service doesn't allow for automatic scheduling, I adjusted it manually instead.
Since then, this error has been occurring.
1048578: Initial configuration not performed.
Terminal block insert.
Can someone help me with this? Thank you!!!
| Description: |
| File size: |
2.94 MB |
| Viewed: |
3036 times |
Translated on 16-07-2026, 3:08.
Profile PM Email |
Driver123 Blaumann
25-03-2022, 14:37 Subject: 1048578 Basic configuration not performed, control panel |
It's a Passat from June 2017.
2.0 TDI engine. 150 horsepower.
Translated on 16-07-2026, 3:09.
Profile PM Email |
Ich_Can_nix Profi-Schrauber
dieselschrauber and Driver123 likes this. |
25-03-2022, 14:49 Subject: 1048578 Basic configuration not performed, control panel |
The control unit has lost its default settings. The maintenance interval was not reset correctly.
Did you also change the oil quality when you adjusted it?
The period is often forgotten.
What exactly did you do / change?
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Michael.
Driver123 Blaumann
dieselschrauber likes this. |
25-03-2022, 15:02 Subject: 1048578 Basic configuration not performed, control panel |
You're welcome. It worked! XX
Ich hatte den Inspektions- u. Service interval.
set to 30,000 km.
Now back to 15,000, no more error messages.
You're welcome.
Translated on 16-07-2026, 3:11.
Profile PM Email |
