Steuergeräte antworten nicht, Audi A6 2.5 TDI (gelöst) | Posts 16+
Go to page: Previous  1, 2
dieselschrauber likes this.
Post14-06-2022, 5:30    Subject: Quote
I suspect this might be related to the ABS (Anti-lock Braking System).
Translated on 13-07-2026, 17:20.
Post14-06-2022, 21:31    Subject: Quote
benschke wrote:
dieselschrauber wrote:
What is definitely not okay is the lack of a 12V power supply for the diagnostic cable. Hopefully, the ignition is always on in this case?
Something's gone wrong.
12V für das Diagnosekabel liegen an (wie oben gezeigt im Screenshot) und Zündung war auch jeweils an.
"I only see the Screenshot from June 9, 2022, at 11:54 AM, and it doesn't show either +12V or ignition being active. Which Screenshot are you referring to?"
Translated on 13-07-2026, 17:22.
benschke
Karma: +9 / -0   Thank you, like it!
2015 Volkswagen Golf
Post15-06-2022, 6:31    Subject: Quote
The fourth post from the top, counting all posts.
I am unable to translate the provided text as it appears to be a hexadecimal code representing an image file name rather than actual text.
1997 Audi A6 Avant, 2,5l TDI (Motor AEL)
2015 VW Golf Variant, 2,0l TDI (Motor CRLB)
1965 VW 1200 (Exportmodell)
Translated on 13-07-2026, 17:23.
benschke
Post15-06-2022, 7:33    Subject: Quote
It involves either the 2x2 cable harness or the connection of contacts to the vehicle or OBD connector.
I managed to connect the interface using a rather unconventional setup, and now I can read data from it.
"Of course, I've already measured the 2x2 connectors before, but I still can't find any defects. I just opened it up (it was clipped together). Everything looks fine inside, and there's continuity on all the cables. It seems like it's not making proper contact with the vehicle or the OBD port somehow."
Thank you to all who helped!
 File size:  3.04 MB
 Viewed:  229 times
Translated on 13-07-2026, 17:25.
Post15-06-2022, 8:15    Subject: Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Translated on 13-07-2026, 17:26.
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MicroCAN: Golf 6 - Control Units Not Responding On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Opel Astra G won't start - Troubleshooting. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Cold start problem with the 1Z engine not solved *cry* Diesel Engine Technology
No new posts ECU Not Available: Troubleshooting & Solutions On-Board Diagnostics (OBD)
