ibiza85
26-05-2021, 8:49 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
Hello everyone
I have the following problem with my Skoda Octavia:
In the morning, when starting the engine for the first time, it runs roughly and stalls. When accelerating, it jerks and sputters. After a short ride or about 2 minutes idling, it runs perfectly. Once it's warmed up, it starts and runs perfectly.
The number of syringes returned in the cold state was checked and is the same for all.
Attached are the logs.
Greetings
Dominik
| Description: |
 Download |
| File name: |
Log-TMBLG7NE1H0047751-122018km-Octavia.txt |
| File size: |
11.3 KB |
| Downloaded: |
501 times |
| Description: |
 Download |
| File name: |
LOG-01-IDE00021_&11.CSV |
| File size: |
46.23 KB |
| Downloaded: |
533 times |
ibiza85
26-05-2021, 8:50 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
Small quantity reconciliation has been performed.
Herbert Profi-Schrauber
dieselschrauber likes this. |
26-05-2021, 11:15 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
The injection time deviation for cylinder 1 is significantly high at idle with a cold engine. Please check the glow plugs. Maybe the pot wasn't (fully) heated.
ibiza85
26-05-2021, 13:42 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
The incandescent bulbs draw approximately 2A of current during the actuator test.
When residual, it's approximately 2.3A.
Unfortunately, I don't have a comparison to a new one.
Joined: 04/12/2002 Posts: 18107 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
26-05-2021, 19:12 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
While the injection times vary, in the 2nd. Log seems relatively normal to me.
What immediately caught my attention was the deviation from the standard fuel pressure regulation.
Please check the wiring and connectors for the fuel pressure sensor and, while observing the log, pay close attention to the setpoint and actual value, and whether the jerking that occurs during a drop in the actual value is present.
Best regards, Rainer
| Description: |
| File size: |
272.81 KB |
| Viewed: |
2785 times |
Profile PM WWW Garage |
ibiza85
26-05-2021, 19:31 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
Thank you, Rainer. I will check it tomorrow.
However, in the 2nd log, it ran normally. It was already warmer at that point.
dr.zikzak
Joined: 02/17/2012 Posts: 68 Karma: +7 / -0 Location: Österreich
20-07-2022, 20:47 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
ibiza85 wrote: | Thank you, Rainer. I will check it tomorrow.
However, in the 2nd log, it ran normally. It was already warmer then. |
What was the final result?
I'm facing a similar problem!
LG Alex
ibiza85
21-07-2022, 7:31 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
The customer did not want to invest any more money, as it was running normally after a few minutes. It has been running and functioning unchanged since then. The problem hasn't gotten any better.
Greetings
dr.zikzak
21-07-2022, 7:39 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
ibiza85 wrote: | The customer did not want to invest any more money, as it had been running normally after a few minutes. It has been running and operating unchanged since then. The problem hasn't gotten any better.
Greetings |
Thank you for your feedback!
LG Alex
ibiza85
21-07-2022, 7:45 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
If you find anything, can you let me know?
dr.zikzak
21-07-2022, 8:24 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
ibiza85 wrote: | | If you find anything, you can let me know. |
That's right!
LG Alex
dr.zikzak
29-09-2022, 6:48 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
The solution has been found:
Replaced the first injector due to the highest return rate, and cleaned all other ultrasound equipment. Final reconciliation of small quantities completed.
The car is now running normally again!
Thank you for the help!
LG Alex
ibiza85
29-09-2022, 7:28 Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. |
Great that the error was found, and thank you for the feedback.
