Adblue System Malfunction – No Error Code or 28653 / P204F (Solution)
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber, chli1976 and Herbert likes this.
Post29-07-2022, 10:16    Subject: Adblue System Malfunction – No Error Code or 28653 / P204F Quote
Adblue System Malfunction – No Engine Start within 1000 Km
If this message appears on the instrument panel, the following procedure can lead to success:
In the A5 Cabrio, 2.0 TDI, CNHA, the warning message appeared due to a leak in the injector's reducing agent ring seal. (Clamp and seal ring replaced - Injector cleaned)
In the Error Log, the following entry was found:
28653 – Reduction System Bank 1
P204F – Unconfirmed Error
The error can be deleted and will not reappear. The error message in the KI still persists. (Even after a 50 km test drive.) There are two (more or less helpful) TPIs on this topic.
TPI 2040064/15 Software error Engine control unit Affects A4, A5, Q5, A6 possibly. Update the software.
TPI 2045062/3 AdBlue System failure - no error entry / error message in the KI.
The latest TPI indicates that the error may have been deleted but is still stored in the control unit. The error can no longer be fixed using the guided troubleshooting procedure but only with a separate diagnostic program (ODIS). (This is stated in the TPI icon_wink.gif)
Please check the values after IDE 08132 SCR Inducement DFCC. Does the value 28653 appear here, then the error message reset due to the missing effectiveness was prevented.
For the A5, there is no "SCR Efficiency Check" dropdown field in the VCDS basic settings.
Therefore, incentive trip will be conducted:
- Atmospheric pressure > 877 hPA
- Ambient temperature > 7 degrees
- System Error-Free
- Coolant temperature > 60 degrees
- DPF Load < 24 g
Conduct a constant speed run so that the maximum speed in the highest gear is 1800 RPM.
SCR Kattemperatur between 210-350 degrees
ACC / GRA disabled
Maintain a speed between 1400-1800 RPM.
Motor Torque between 80-270 Nm
If all conditions are met – maintain a 5 sec sailing profile and then abruptly transition to full throttle. (Sail completely off the gas). The diagnosis should be made now.
If the efficiency is satisfactory – the message is immediately cancelled.
Best regards
Michael
Ratings - Adblue System Malfunction – No Error Code or 28653 / P204F
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Particulate Filter Failure: Causes & Solutions Diesel Engine Technology
No new posts AdBlue Check: 1050 km Range Diesel Engine Technology
No new posts Adjusting the Adblue Warning Threshold with VCDS On-Board Diagnostics (OBD)
No new posts No Oil Pressure? 1.6 AEA Engine Help Gasoline Engine Technology
