Passat 3C: Boost Pressure Too Low - Troubleshooting
Golf2Turbodriver
Post15-08-2022, 20:54    Subject: Passat 3C: Boost Pressure Too Low - Troubleshooting Quote
I need some help with this error. I've attached the Autoscan.
Can we already see from here what it might be caused by?
Greetings.
BA_QQ8_220815.pdf
 File name:  BA_QQ8_220815.pdf
 File size:  148.18 KB
 Downloaded:  523 times
Translated on 24-09-2026, 15:56.
Post16-08-2022, 20:35    Subject: Passat 3C: Boost Pressure Too Low - Troubleshooting Quote
VTG adjustment lever not retracting properly.
or
Turbocharger air intake system leak:
Translated on 24-09-2026, 15:57.
Golf2Turbodriver
Post17-08-2022, 18:57    Subject: Passat 3C: Boost Pressure Too Low - Troubleshooting Quote
Thank you. I've checked it, but unfortunately, I couldn't find anything. I've noticed that the error only occurs when I drive with the cruise control for a while, or when I keep my foot on the accelerator for an extended period. icon_smile_thumb_up.gif
I've also noticed that it makes a rattling noise at low RPMs when accelerating.
Translated on 24-09-2026, 15:58.
Post19-08-2022, 12:40    Subject: Passat 3C: Boost Pressure Too Low - Troubleshooting Quote
I've noticed that the error only occurs when I drive with the cruise control engaged for a while, or when I keep my foot on the accelerator for an extended period.
It's possible that your VTG (variable transmission gear) is simply stiff.
You can apply a small amount of copper-based assembly paste where the VTG lever connects to the loader, just in case the adjustment shaft gets stuck (which is unlikely but possible).
If the VTG (Variable Turbine Geometry) adjustment mechanism is stuck internally, the only solution is to disassemble it or replace the turbocharger altogether.
Translated on 24-09-2026, 15:59.
No new posts Boost Pressure Limit Reached (BLS) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost pressure control exceeded 3.0 bar, P0299 code / rou... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 BKD, boost pressure regulation limit exceeded Diesel Engine Technology
No new posts AUY: Limit Breached, Below Threshold Diesel Engine Technology
No new posts T5, Multivan: Turbocharger pressure control, regulation l... Diesel Engine Technology
No new posts P0299: Load Pressure Control - Control Limit Undershot Diesel Engine Technology
