Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures.
ibiza85
Post26-05-2021, 8:49    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
Hello everyone
I have the following problem with my Skoda Octavia:
In the morning, when starting the engine for the first time, it runs roughly and stalls. When accelerating, it jerks and sputters. After a short ride or about 2 minutes idling, it runs perfectly. Once it's warmed up, it starts and runs perfectly.
The number of syringes returned in the cold state was checked and is the same for all.
Attached are the logs.
Greetings
Dominik
Log-TMBLG7NE1H0047751-122018km-Octavia.txt
 File name:  Log-TMBLG7NE1H0047751-122018km-Octavia.txt
 File size:  11.3 KB
 Downloaded:  511 times
LOG-01-IDE00021_&11.CSV
 File name:  LOG-01-IDE00021_&11.CSV
 File size:  46.23 KB
 Downloaded:  551 times
ibiza85
Post26-05-2021, 8:50    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
Small quantity reconciliation has been performed.
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post26-05-2021, 11:15    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
The injection time deviation for cylinder 1 is significantly high at idle with a cold engine. Please check the glow plugs. Maybe the pot wasn't (fully) heated.
ibiza85
Post26-05-2021, 13:42    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
The incandescent bulbs draw approximately 2A of current during the actuator test.
When residual, it's approximately 2.3A.
Unfortunately, I don't have a comparison to a new one.
Post26-05-2021, 19:12    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
While the injection times vary, in the 2nd. Log seems relatively normal to me.
What immediately caught my attention was the deviation from the standard fuel pressure regulation.
Please check the wiring and connectors for the fuel pressure sensor and, while observing the log, pay close attention to the setpoint and actual value, and whether the jerking that occurs during a drop in the actual value is present.
Best regards, Rainer
 File size:  272.81 KB
 Viewed:  2805 times
ibiza85
Post26-05-2021, 19:31    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
Thank you, Rainer. I will check it tomorrow.
However, in the 2nd log, it ran normally. It was already warmer at that point.
dr.zikzak
Post20-07-2022, 20:47    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
However, in the 2nd log, it ran normally. It was already warmer then.
What was the final result?
I'm facing a similar problem!
LG Alex
ibiza85
Post21-07-2022, 7:31    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
The customer did not want to invest any more money, as it was running normally after a few minutes. It has been running and functioning unchanged since then. The problem hasn't gotten any better.
Greetings
dr.zikzak
Post21-07-2022, 7:39    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
ibiza85 wrote:
The customer did not want to invest any more money, as it had been running normally after a few minutes. It has been running and operating unchanged since then. The problem hasn't gotten any better.
Greetings
Thank you for your feedback!
LG Alex
ibiza85
Post21-07-2022, 7:45    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
If you find anything, can you let me know?
dr.zikzak
Post21-07-2022, 8:24    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
ibiza85 wrote:
If you find anything, you can let me know.
That's right!
LG Alex
dr.zikzak
Post29-09-2022, 6:48    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
The solution has been found:
Replaced the first injector due to the highest return rate, and cleaned all other ultrasound equipment. Final reconciliation of small quantities completed.
The car is now running normally again!
Thank you for the help!
LG Alex
ibiza85
Post29-09-2022, 7:28    Subject: Octavia 1.6 TDI CXXB has jerky movements, clunks, and intermittent failures. Quote
Great that the error was found, and thank you for the feedback.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 2.0 TDI: Intermittent Power Loss & Misfires Diesel Engine Technology
No new posts Skoda Octavia 1.6 TDI DDYA - Misfires/Jerking during cold... Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI Injector Problems: Golf 7 Variant 1.6 CXXB Diesel Engine Technology
No new posts CXXB Injectors: Loud Backfire & Rough Running Diesel Engine Technology
