AEY 1.9 SDI VP37: Start & Bleed Procedure
Terminator96
Post18-10-2022, 18:58    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
Hello everyone,
"Since my engine occasionally stalls, first exhibiting symptoms like rough idling and unexpected acceleration during downshifts, and because the ESP system is throwing various error codes, I want to replace both the timing belt and the ESP unit completely (mostly due to issues with the variable valve timing). However, I wouldn't have thought that a misadjustment could cause the engine to stall while it's already running. I myself drove for 3,000 km with a completely faulty pump."
Just to mention, the previous owner had already replaced the mass airflow sensor with a different one and adjusted it manually. Also, all the cables coming from the wiring harness were cut and reconnected using crimp connectors. I've never seen anything like that before. Apparently, he drove the car for 60,000 km with those issues. It's amazing that it even ran. While driving, you almost don't notice the shoddy workmanship. Since it suddenly stopped working, I have to replace everything completely now. I got a refurbished one from KS Turbo.
I've done some research here and have two more questions.
"The VP37 is an electronic component. Do I need a dial gauge for installation, or can I simply transfer the old toothed wheel from the other defective pump and connect it? Basically, just screw the pump centrally into the elongated holes. Place the toothed wheel onto the pump. Finally, rotate the pump's wheel clockwise until the locking pin fits in? Then put on the timing belt, check if everything aligns correctly, and the engine will definitely start 100%? If that's the case, I don't need the dial gauge anyway, because I can adjust/monitor the rest dynamically using VCDS?"
2.: How do I bleed the pump, as it will be empty? Do I need a separate vacuum pump for this, or can I simply suck on it somewhere (polish with my mouth icon_biggrin.gif)?
Translated on 26-07-2026, 5:19.
dieselschrauber likes this.
Post18-10-2022, 19:09    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
What should I write here now...? X X
Translated on 26-07-2026, 5:21.
Post18-10-2022, 19:15    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
A clear case...
OBD Support Key
Terminator96
Post18-10-2022, 19:24    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
Okay... did I do or say something wrong?
Post18-10-2022, 19:27    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
Terminator96 wrote:
Okay... did I do something wrong/say something wrong?
Just click on the images.
Translated on 26-07-2026, 5:22.
Post18-10-2022, 20:35    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
...and below, everything necessary is automatically displayed... �
Post19-10-2022, 5:20    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
Unfortunately, you don't immediately notice that on your phone.
Post19-10-2022, 18:41    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
...and below, everything necessary is automatically displayed... X
Disassembly of the magazine assembly for a VP37. Troubleshooting & instructions.
Replacing the upper seal on a VP37 injection pump. Troubleshooting and instructions.
Repair of a distributor head for a VP37 injection pump. Troubleshooting and instructions.
Static boost start AFN (VP37) Diesel engine technology.
Set the start date for subsidy for VW SDI 1.7 VP37
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Translated on 26-07-2026, 5:24.
Post19-10-2022, 19:44    Subject: AEY 1.9 SDI VP37: Start & Bleed Procedure Quote
I know, but maybe he just missed it...
Translated on 26-07-2026, 5:25.
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Static Boost Start AFN (VP37) Diesel Engine Technology
No new posts Ignition timing jumps around at VP37 in VW T4 ACV Diesel Engine Technology
This topic is locked, you cannot edit or reply. Kurbelwellengehäuse-Entlüftung Diesel Engine Technology
No new posts VP44 Bleeding: Forum User Question Diesel Engine Technology
