Can you use an EDiTH Eberspächer with a VCDS HEX-V2 K-Line?
ibiza85
Post14-12-2022, 8:22    Subject: Can you use an EDiTH Eberspächer with a VCDS HEX-V2 K-Line? Quote
Hello everyone.
I would like to be able to read data from an Eberspächer Airtronic air heater installed in a camper van via the K-Line interface. Is that possible with the HEX-V2?
Dominik.
Translated on 05-07-2026, 18:54.
Post14-12-2022, 19:25    Subject: Can you use an EDiTH Eberspächer with a VCDS HEX-V2 K-Line? Quote
To the best of my knowledge, it is not available due to the lack of a corresponding driver. It would have worked with the HEX-USB+CAN.
I would get an interface with KKL (K-Line communication) that connects via serial. If it uses an FTDI chipset, the "latency setting" might be helpful, but it's probably not strictly necessary.
Translated on 05-07-2026, 18:55.
ibiza85
Post15-12-2022, 8:11    Subject: Can you use an EDiTH Eberspächer with a VCDS HEX-V2 K-Line? Quote
Thank you for the response.
I still have the old HEX+CAN ISO 9141 cable. Would that work?
Dominik.
Post15-12-2022, 8:15    Subject: Can you use an EDiTH Eberspächer with a VCDS HEX-V2 K-Line? Quote
Dominik
Yes, there's a driver available for download in the customer account, and in the VCDS program settings, you can switch to KKL (I don't remember the exact name, something like "dummy interface" or similar).
If you need it frequently, it's better to get your own KKL (Key Cutting Machine).
Translated on 05-07-2026, 18:56.
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Airtronic D2 Defective: Troubleshooting Smoke Issues General Tips
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Run AXR without LLM Diesel Engine Technology
No new posts Knee Pain Relief: The K/L Scale Explained Diesel Engine Technology
No new posts Operating AFN with AHU/1Z Injection Pump Diesel Engine Technology
No new posts Connecting the second one. K-Line On-Board Diagnostics (OBD)
