Climatronic Display Flashing: Troubleshooting Guide
alex-on-line.de
Post08-11-2003, 16:14    Subject: Climatronic Display Flashing: Troubleshooting Guide Quote
'Since yesterday, I've been having a problem where the display flashes when I turn on the ignition. (all the characters/symbols).'
After about 15 seconds, it stops, and the Climatronic system starts working normally again.
Before, I always had the problem that the outside temperature initially displayed 10°C and only adjusted to the correct value after a few minutes.
What could that be? (Especially the blinking.)
Thank you for your help.
(Volkswagen Golf III TDI, manufactured in 1995)
P.S. Can climate codes already be applied with this Climatronic system?
Translated on 28-09-2026, 10:58.
Post08-11-2003, 17:17    Subject: Climatronic Display Flashing: Troubleshooting Guide Quote
"Regarding the codes, you should definitely try it, as it allows you to clear the error memory. The flashing display indicates that there's an error. Search for "Climacodes" here or on Google. I have a Golf with a different system, so I can't help you with that!"
Translated on 28-09-2026, 11:00.
alex-on-line.de
Post08-11-2003, 20:14    Subject: Climatronic Display Flashing: Troubleshooting Guide Quote
I tried using 'Econ', 'blue', and '-', but it didn't work.
I pressed them evenly on all sides.
Post09-11-2003, 10:28    Subject: Climatronic Display Flashing: Troubleshooting Guide Quote
That's correct; the code is for the new devices.
alex-on-line.de
Post09-11-2003, 10:53    Subject: Climatronic Display Flashing: Troubleshooting Guide Quote
Can someone please just give me the correct keyboard shortcut?
I really can't find any other option!
Translated on 28-09-2026, 11:01.
hturborbo01
Post11-11-2003, 18:27    Subject: Climatronic Display Flashing: Troubleshooting Guide Quote
I've experienced something similar.
It turned out that the...
The electrically powered fan was broken.
First, the air conditioner starts up normally.
If then, on the evaporator (cooler), the...
If the temperature is not right, it will fail.
Cold compressor turned off.
With the engine running (idling), activate the air conditioning.
exercise.
After a short period, the electric fan...
If it doesn't start in the engine compartment, you can...
assume that this is defective.
While driving, the air conditioning system may fail.
Do not turn on the fan, as the airflow from the vehicle will provide sufficient ventilation.
Hturbo01
Translated on 28-09-2026, 11:02.
No new posts Doku Polo MJ 2001, Climatronic display blinking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 2 MFA Display: How to Separate On-Board Diagnostics (OBD)
No new posts The display in the instrument cluster is not showing anyt... On-Board Diagnostics (OBD)
No new posts Tire pressure monitoring display - Deactivated Transmission, Chassis, Body & Interior
No new posts Audi FIS Display: EFU Starter Kit by eifeltacho.de Diesel Engine Technology
