t4 wfs deaktivieren | Posts 16+
Go to page: Previous  1, 2
dieselschrauber and E30_V8 likes this.
Post18-11-2022, 7:02    Subject: Quote
If you plan to own your Volkswagen vehicle for a longer period, consider VCDS as an investment that will pay off in the future. I bought it in 2015 and regret not having purchased it sooner.
My cars are also all from the early 2000s and don't have a CAN bus. I've owned a VAG 1551 for over 20 years, but using VCDS makes many things much more convenient.
Translated on 12-08-2026, 17:59.
Post18-11-2022, 19:05    Subject: Quote
It sounds like a problem with the Wastegate Function (WFS), but only reading the error codes from the engine control unit will confirm it.
Unfortunately, I don't know of any companies that fit the description. Perhaps the user @Bloesch can help you. However, I'm not sure if I'm misunderstanding something.
A chip tuner should be able to disable WFS, or you can simply purchase an identical engine control unit (ECU) that already has WFS disabled.
PS: Thanks for the coffee! X
Translated on 12-08-2026, 18:01.
johnwolf
Post30-11-2022, 16:32    Subject: Quote
I've now found a workshop that can read [data/information].
"Is it possible to do this while the engine is running or with the ignition on?"
Currently, I can only start the car a maximum of once per week.
If I have it physically present, turn it off, and then it stops working...
Translated on 12-08-2026, 18:02.
E30_V8 likes this.
Post30-11-2022, 18:41    Subject: Quote
Hello.
t4 2.5 gasoline 1995
I would be surprised if that's possible when it's installed.
Surely the person who can disable the WFS should be able to answer that question, shouldn't they?
My suggestion would be to obtain an identical used engine control unit (ECU) and have the Waste Heat System (WFS) deactivated in it.
Translated on 12-08-2026, 18:03.
johnwolf
dieselschrauber likes this.
Post02-12-2022, 18:01    Subject: Quote
It's working again.
Key number 2 appeared today. With that, it's working.
When switching to key 1, it turns off as usual after 2 seconds.
I then drove the car into the garage, and it displayed an error message: "1176 key." I have an appointment on Thursday with another garage; they're going to try to copy the existing second key onto the original first key.
Translated on 12-08-2026, 18:04.
Post02-12-2022, 18:34    Subject: Quote
Alternatively, you can directly attach the intact transponder to the reading coil...
Translated on 12-08-2026, 18:05.
johnwolf
Post02-12-2022, 21:07    Subject: Quote
"Until someone can plausibly explain to me how an RFID chip could simply break (the key was only used a maximum of two times), I can't afford this fiasco with an automatic transmission and the problems with the garage, since the T4 is too old. No way, no second key – I wouldn't dare."
Karma: +591 / -0   Thank you, like it!
Post02-12-2022, 21:53    Subject: Quote
Hello!
Yes, I agree with you.
I would also make one or two backups there.
Because if the replacement transponder also fails, then you're in trouble.
Hmm, I haven't done it myself yet, but years ago while browsing through VCDS, I saw that there seems to be a function for programming transponders like that.
Hmm, it's been a long time, but back then, car keys or spare keys used to have this small black plastic strip with some numbers on it.
Do you have that?
Translated on 12-08-2026, 18:07.
Post03-12-2022, 7:30    Subject: Quote
Transponders can fail or lose data, even without falling off.
chup4
2001 Audi A2
Post11-12-2022, 15:22    Subject: Quote
It depends on what information you have about the car.
"There should have been a small tag attached to the keys with a four-digit code on it; that's the login code. However, for some older devices, it's possible to read out (or have someone read out) the login code via the K-line interface. Someone in your area would need to do that."
Translated on 12-08-2026, 18:08.
johnwolf
Rüdi and E30_V8 likes this.
Post28-12-2022, 21:37    Subject: Quote
The car is running again.
I finally found a garage that could read the error codes. The error code was XY = faulty key.
That same week, my grandfather actually found the spare key that had been missing for years.
I went to a Turkish colleague who runs a shoe and key service business.
He then tried to read the old key, but there was no signal, so it was completely dead.
So, it seems that the car was occasionally running again in October/November, despite the issues.
Then we loaded the second key and it's running.
We copied it then.
cost (RFID chip: 20 euros)
work (30e)
Okay, so I have two keys again now.
Therefore, the WFS can remain in place because I still haven't found a pre-programmed MSG (Message Sequence Number).
Best regards.
Translated on 12-08-2026, 18:10.
Post29-12-2022, 11:29    Subject: Quote
Thank you for your feedback!
Translated on 12-08-2026, 18:11.
No new posts Disable AGR? Diesel Engine Technology
No new posts Deactivate front passenger airbag Diesel Engine Technology
No new posts Disable headlight failure detection (VW up!) Electrical Systems, Vehicle Electronics, Multimedia
No new posts Deactivate Front Passenger Airbag in AKN Car Transmission, Chassis, Body & Interior
