Camshaft Worn or Lifters? Metal in Oil Filter
TTS1982
Post16-03-2023, 15:52    Subject: Camshaft Worn or Lifters? Metal in Oil Filter Quote
Hello everyone,
I have a V6 3.0 engine (with approximately 270,000 km on it), and recently, out of nowhere, I started hearing a sound like a Lanz Bulldog with a single cylinder icon_biggrin.gif.
Then I removed the cylinder head cover and checked the water pump while manually rotating the engine. It didn't appear to be damaged, and I didn't see any metal shavings.
"Since I've been experiencing occasional misting around the engine and it's been having trouble starting, I decided to replace the injectors first, as they were due for replacement anyway."
Unfortunately, nothing helped. The loud knocking sound from the direction of cylinder 6 continues.
Then I removed the vacuum pump, but the knocking sound persisted.
Now, I took the head off and then saw that the hydraulic lifters for cylinder 6 are broken... I should have noticed it when I removed the valve cover the first time icon_rolleyes.gif.
It is what it is; I'll just replace the crankshaft seals at the same time. The EGR cooler also always smelled a bit funny, probably because it was leaking due to bubbling inside the heat exchanger.
Now, to my actual questions:
1) Have my options expired?
I think they look good visually, but there's a slight "depression" that can be felt on the tread surface in front of the groove, both at the beginning and end.
"But Haarwinkel says, 'Can't you see!'"
I hope the pictures are okay; otherwise, I can send some more.
I would really appreciate it if someone could help me here.
2) I found metal shavings in the dried oil filter. However, I didn't find any signs of wear on the connecting rods, crankshaft, or cylinder walls.
I disassembled my HDD and took it apart; there are no scratches on the platters, and everything looks good.
Where could they possibly come from?
Best regards from the garage icon_smile_thumb_up.gif.
 File size:  2.86 MB
 Viewed:  554 times
 File size:  2.01 MB
 Viewed:  586 times
 File size:  3.21 MB
 Viewed:  1021 times
Translated on 04-08-2026, 17:58.
No new posts Debris and fragments in engine oil bind General Tips
No new posts **Hydrostößel: Construction and Function** **Construct... Technical Articles
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Nockenwelle eingelaufen, Hydros durchgeschlagen Diesel Engine Technology
No new posts Camshaft Wear: New Part Failed Quickly? Diesel Engine Technology
No new posts Hydraulic lifters or fuel injectors? Diesel Engine Technology
No new posts Dimensions for adjustment or locking ruler for camshaft Diesel Engine Technology
