[1.9sdi AYQ] Static boost start
tesla
Post01-04-2023, 17:02    Subject: [1.9sdi AYQ] Static boost start Quote
Hi everyone!
"I'm Jan, and I'm new here. I've been working with diesel technology and LPG for quite some time. I'm mainly interested in older vehicles manufactured before the year 2000. I like to buy inexpensive used vehicles and then prepare them for my own use."
So, I'm more of an ambitious hobbyist when it comes to tinkering and fixing things.
Regarding my issue:
I'm currently in the process of replacing the fuel injection pump on my Caddy 9KV 1.9SDI with a used one (due to a loud knocking noise caused by a faulty injection timing adjuster). Now, I'm wondering if there's a static injection start setting for the SDI pumps that can be adjusted using a pressure gauge. Unfortunately, I don't have VCDS yet, and I want to get the Caddy running first.
Unfortunately, the used pump was not calibrated to OT (Operating Temperature) before it was removed.
Sure! Here's the translation:
"Thank you very much!"
The Jan.
Translated on 08-07-2026, 18:31.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber likes this.
Post01-04-2023, 20:34    Subject: [1.9sdi AYQ] Static boost start Quote
Hello Jan,
You can precisely adjust the camshaft timing using a camshaft alignment tool.
The corresponding tool (OE part number T10098 A) costs around 20 euros.
The pump is adjusted to 0.70 mm +/- 0.02 mm using a measuring instrument.
The fuel injection system is checked using a diagnostic tool.
You can find the tool here in the shop, as well as further support.
https://shop.dieselschrauber.org/en/vcds-diagnose-fuer-audi-seat-skoda-und-vw-c-23.php
Michael.
Translated on 08-07-2026, 18:32.
tesla
Post02-04-2023, 22:12    Subject: [1.9sdi AYQ] Static boost start Quote
Thank you for the response!
Habe heute alles wieder zusammen gebaut und dementsprechend eingestellt. Leider räuchert der Motor immer noch stark weiß und entwickelt keine Leistung. Das deutet ja alles auf Einspritzbeginn `spät´ hin. Denke, dass meine Messuhr eventuell nicht richtig geht. IcI don't understand.
Take the car to the independent garage on Tuesday and have them properly adjust the pump.
Translated on 08-07-2026, 18:33.
No new posts Start of ESP funding Diesel Engine Technology
No new posts T4 2.5 TDI: Fuel injection timing fluctuates On-Board Diagnostics (OBD)
No new posts Funding start dependent on the amount of funding Diesel Engine Technology
No new posts Funding Start: 1/1552 On-Board Diagnostics (OBD)
