AGM gegen EFB tauschen? | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1349 / -0   Thank you, like it!
dieselschrauber likes this.
Post12-05-2023, 9:22    Subject: Quote
vag-driver wrote:
With the multimeter, I measured 1.76 MΩ on the terminals.
How? What? Between the poles of the charged battery?
Translated on 06-07-2026, 15:35.
vag-driver
Post12-05-2023, 10:16    Subject: Quote
Yes, on the terminals of the connected battery.
Andreas
dieselschrauber and Herbert likes this.
Here, values of approximately 4-6 milliohms are expected for a healthy starter battery.
That's not easily done with a multimeter. There are battery testers available for that, and they can be quite affordable. They also evaluate the displayed value.
If the multimeter was actually connected in parallel to the battery in the resistance measurement mode, the internal fuse could have blown. This could also result in readings in the megaohm range. In other words: an open circuit.
Post12-05-2023, 11:20    Subject: Quote
vag-driver wrote:
Yes, on the poles of the connected battery.
In the manual for my Fluke DMM, it states "Ensure that the device being measured contains no electrical energy". This likely applies generally to resistance measurements.
The only meaningful way would have been to measure it with a battery tester. "You draw 400 amps, observe the voltage to see if it remains within the expected range (and you can calculate the internal resistance)."
By the way, shouldn't this thread perhaps be deleted?
Translated on 06-07-2026, 15:37.
Ich_Can_nix
Post12-05-2023, 11:51    Subject: Quote
Hello Andreas,
As an alternative to a multimeter, VCDS is also an option.
Here, you can query the collected values from the IBS.
For an initial overview, all the relevant data is conveniently displayed here. Depending on the IBS (Intelligent Battery System), it may even be possible to query the SOH (State of Health) of AGM (Absorbent Glass Mat) batteries.
Michael.
 File size:  353.49 KB
 Viewed:  380 times
Translated on 06-07-2026, 15:38.
vag-driver
Post12-05-2023, 13:06    Subject: Quote
I'll take a look at it using VCDS. Nothing seems to be burnt out on my Fluke. It works perfectly.
Andreas
Translated on 06-07-2026, 15:39.
vag-driver
Post15-05-2023, 7:54    Subject: Quote
The internal resistance is showing as 4.8 mOhms. Battery aging at approximately 80%.
Andreas
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts MFA for FIS swap On-Board Diagnostics (OBD)
No new posts Replacing the 8V particulate filter with the 16V catalyti... Diesel Engine Technology
No new posts Replace Single Fan with Dual Fan Diesel Engine Technology
No new posts Exchange Old MFA/BC for New? Transmission, Chassis, Body & Interior
