Label file issues
Kevgo24
Post03-08-2023, 16:34    Subject: Label file issues Quote
Good day everyone, this is my first post here, so things might not be perfect yet, please bear with me.
It's a 2007 Audi RS4 B7 with a V8 engine (BNS).
Okay, so here's my problem: I had the engine software modified, and now my VCDS can't find a matching label file anymore, probably because the tuner changed the software.
I found a post where someone else had a similar problem, but it's not working for me the same way.
Perhaps someone here can help me with this, and I would be very grateful for it.
Post03-08-2023, 16:42    Subject: Label file issues Quote
You need to know which label file was previously used for the engine control unit, for example, by using an old car scanner. Otherwise, the on-board diagnostics (OBD) system can help, and in the worst case, you can check what information is stored in the engine control unit (ECU).
Then, using VCDS, check what part number is displayed in the engine control unit software.
Then, you copy the previous label file and give it the name (keeping the same extension) that VCDS displayed for the modified control unit.
I believe that tuners renaming software is a bad practice; it only causes stress. "Someone who knows how to, can figure out which software it is, and as a customer, I want to be able to see what's going on in case of an error, and I don't want it to say something like 'File made by Superman'." icon_wink.gif
Post03-08-2023, 16:50    Subject: Label file issues Quote
; 079-909-559-BNS1.LBL (4.2l FSI @ 420 HP - BNS - Master)
; 079-909-559-BNS2.LBL (4.2l FSI @ 420 HP - BNS - Slave)
; 079-909-559-BNS3.LBL (4.2l FSI @ 420 HP - BNS - Other)
So, append the modified names, which are 1, 2, and 3, to the files when you copy them. icon_idea.gif
Kevgo24
Post03-08-2023, 21:10    Subject: Label file issues Quote
So, append the numbers 1, 2, and 3 to the end of the filenames when you copy the files. icon_idea.gif
Hi, thanks so much for the reply. I no longer have the old scan. Yes, I agree with you; they really should just leave the software version number alone.
I've uploaded the latest scan.
 Label file issues
 File size:  434.99 KB
 Viewed:  298 times
Post03-08-2023, 22:46    Subject: Label file issues Quote
RS-KLINIK.DE1.LBL
RS-KLINIK.DE2.LBL
RS-KLINIK.DE3.LBL
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Label File: Create, Edit, and Print Labels On-Board Diagnostics (OBD)
No new posts Missing Label: 8Y0920790 - Find Yours Now! On-Board Diagnostics (OBD)
No new posts ECU Label File: Find Yours Now! On-Board Diagnostics (OBD)
No new posts Golf 3 TDI Label File: Where to Find It Diesel Engine Technology
