T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Damaged (Solution)
Turbinchen likes this.
Post20-10-2023, 19:05    Subject: T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Damaged Quote
Today, I found that the water tank in my T6 was empty, even though I had filled it just last weekend.
While searching for the cause, I noticed the inserted pump. The seal that fits into the suction tube seems a bit loose, and directly underneath, where the hoses connect to the pump, there was a drop of water.
As a quick fix, dry the suction nozzle of the pump thoroughly and then wrap it with 2 layers of insulating tape to slightly increase the diameter. Now sits tighter in the rhyme, whether it rhymes, the days will show.
To access the windshield washer pump, you don't need to remove anything major. A valve in the left front fender well can be opened with a large screwdriver.
Best regards, Rainer
 File size:  125.27 KB
 Viewed:  2403 times
 File size:  131.9 KB
 Viewed:  1955 times
Post07-11-2023, 22:57    Subject: T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Damaged Quote
It is still leaking. Attaching the pump to the container also didn't help.
I have also noticed that the windshield washer hoses may have been damaged, and they were also no longer clipped onto the hood hinges. icon_rolleyes.gif new_shocked.gif
Possibly, the hose connections on the pump are also damaged.
Unfortunately, the bumper needs to be removed because you can't see anything clearly and the leak isn't obvious either. After 3 days, the tank is empty again. icon_evil.gif
dieselschrauber, Herbert and E30_V8 likes this.
Post09-11-2023, 20:34    Subject: T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Damaged Quote
On the Passat 3C, the windshield washer hose is often damaged by the bumper. Dieselmartin had once set up something here many years ago.
I had the same problem back then with my 3C.
Why am I writing to you about T6? The water will flow down the hose later and collect at the bottom near the pump. This means you might need to look a bit higher than at the bottom near the pump. If necessary, wrap the pipe with a kitchen towel and ensure that it remains dry over a longer period.
Post19-11-2023, 15:03    Subject: T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Damaged Quote
The level of distress increased again to the point that I started further investigations.
The two spray hoses from the pump, going upwards, were inspected in the relevant area and were found to be in good condition. Furthermore, the expansion is actually quite complex; the Radhausschale needs to be removed, and if you're unlucky, the bumper as well. icon_evil.gif
Fortunately, I was able to remove the front part of the Radha valve for the inspection, and then the hoses could be seen/checked up to the height of the windshield washer fluid reservoir.
I saved myself the trouble of taking the test, because water doesn't flow uphill for nothing, and even if there was a leak, it couldn't be the cause of the container emptying while it was stationary.
After partial filling with wash water concentrate, the only blue drops I could find were directly at the pump's hose connection. There was quite a bit of dripping.
The gasket in the fitting appeared slightly compressed in one area, and my first attempt was to replace it.
After about 15 minutes of fiddling with a paperclip and various O-rings, I, frustrated, decided to simply insert a piece of silicone tubing directly into the pump nipple and the cut-off spray hose. Secured with cable ties, just to be safe. Now, no more drops can be seen.
Therefore, I am confident that it really works, whether it does or not will become clear in the next few days. icon_lol.gif
 File size:  2.26 MB
 Viewed:  503 times
 File size:  2.72 MB
 Viewed:  401 times
Herbert likes this.
Post05-01-2025, 20:27    Subject: T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Damaged Quote
Ratings - T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Damaged
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B2 Achsmanschette undicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leaky AVF AGR Valve: Causes & Fixes Diesel Engine Technology
No new posts Defective candle Diesel Engine Technology
No new posts ABS/ESP Leak: Find the Source! Diesel Engine Technology
No new posts Ölfilter undicht Diesel Engine Technology
