DPF Failure: A4 2.0 TDI CNHC Engine
tg.mayer
Post19-11-2023, 18:48    Subject: DPF Failure: A4 2.0 TDI CNHC Engine Quote
Hello, fellow diesel mechanics!
"In my A4 B8 2.0 TDI with DPF, the following diagnostic trouble code (DTC) has been registered in the engine control unit for a few weeks: "Particulate Filter Bank 1 Malfunction." I have already cleared the error code, but it reappears. The check engine light comes on repeatedly as a result. The regeneration process seems to be working because the time elapsed and the distance traveled since the last regeneration are not that long. The soot mass is also not excessively high and decreases during longer highway driving. So far, I suspect the differential pressure sensor may need to be replaced."
I would appreciate any feedback on errors.
Excerpt from the minutes:
19226 - Particle filter, bank 1.
P2002 00 [101] - Malfunction.
Unconfirmed - Checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2.
Error frequency: 1.
Mileage: 135,884 km
Date: 2023.11.18
Time: 12:23:53
Motor speed: 1703.00 rpm.
Normalized load value: 45.9%
Vehicle speed: 64 km/h.
Coolant temperature: 91 °C.
Intake air temperature: 63 °C
Ambient air pressure: 1000 millibars.
Voltage at terminal 30: 14,500 V.
Lost learning counter via OBD: 40.
Exhaust mass flow rate of the low-pressure exhaust gas recirculation (EGR) system: calculated value = 3,010.
Differential pressure ratio: Low-pressure EGR: 26.7 kg/h.
Abgasrückführung 2: Differenzdruckgeber 1 Bank 1: ad. Wert: 28.7 hPa
Exhaust Gas Recirculation (EGR) 2: Differential Pressure Sensor 1 Bank 1: Raw Value: 30.6 hPa.
Exhaust control valve bank 1, cylinder 1: In stock. Actual value: 72.77%.
Exhaust gas recirculation valve, bank 1: In stock. Actual value: 46.68%.
Exhaust Gas Recirculation (EGR) 2: Differential Pressure Sensor 1 Bank 1: dynamic value: 26.5 hPa.
 File size:  30.48 KB
 Viewed:  891 times
 File size:  33.74 KB
 Viewed:  783 times
Translated on 26-07-2026, 21:08.
Post19-11-2023, 19:10    Subject: DPF Failure: A4 2.0 TDI CNHC Engine Quote
see:
Read and understand what is written there. I don't want to see any posts yet, because otherwise relevant things like the differential pressure at full load will be missing again. icon_idea.gif
Translated on 26-07-2026, 21:12.
No new posts Variable valve timing malfunction General Tips
No new posts Central Locking Failure: A6 Doku 4B (10/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P1405 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF malfunction On-Board Diagnostics (OBD)
No new posts CFWA - Diesel Particulate Filter Malfunction Diesel Engine Technology
No new posts Print Error P1297 & P1093: Troubleshooting Guide Gasoline Engine Technology
This topic is locked, you cannot edit or reply. TDI Injector Problems: Golf 7 Variant 1.6 CXXB Diesel Engine Technology
