Golf 5 Variant ABS/ESP deviations in wheel speed
Karma: +645 / -0   Thank you, like it!
Post18-11-2023, 17:35    Subject: Golf 5 Variant ABS/ESP deviations in wheel speed Quote
Hi.
I have a Golf 5 Variant TDI from October 2008.
The ESP (Electronic Stability Program) light starts to illuminate at speeds of approximately 50 km/h.
VCDS is connected, and the left front wheel exhibits a consistent lead in rotation compared to the other wheels. The faster you drive, the greater this difference becomes.
I don't know if the problem existed before, as a faulty steering angle sensor had disabled the ESP. I replaced the steering gear and also the faulty wheel bearing on the front left side at the same time.
Did I cause the problem myself by installing a faulty sensor or magnetic ring on the new wheel bearing, and could the ABS sensor be the cause...?
There are no error messages.
Thank you very much.
Rüdi and Herbert likes this.
Post18-11-2023, 20:15    Subject: Golf 5 Variant ABS/ESP deviations in wheel speed Quote
My first thought was "the wrong wheel bearing was installed."
Is the sensor ring larger than on the other wheels?
dieselschrauber likes this.
Post20-11-2023, 4:21    Subject: Golf 5 Variant ABS/ESP deviations in wheel speed Quote
I still need to add some information: Currently, tires of size 205/55R16 are mounted, and all tires are from the same manufacturer with identical tire pressure.
When I had 195/65R15 tires before, it was possible to drive without the ABS/ESP system activating.
dieselschrauber and Steffen G likes this.
Post11-02-2024, 20:24    Subject: Golf 5 Variant ABS/ESP deviations in wheel speed Quote
Hi.
Briefly, the cause was a misaligned axle geometry due to the used steering gear.
After the wheel alignment, everything was okay.
Best regards, Rüdi.
Post11-02-2024, 20:55    Subject: Golf 5 Variant ABS/ESP deviations in wheel speed Quote
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASD AFN Golf Variant: What do you think? Diesel Engine Technology
No new posts Golf 6 Variant: Heated Steering Wheel Transmission, Chassis, Body & Interior
No new posts Golf 3 Variant Net Separator Grill Transmission, Chassis, Body & Interior
No new posts Audi S3 Alloy Wheels on VW Golf IV Variant? Transmission, Chassis, Body & Interior
