Vehicle Diagnostics Protection (VDP)
Go to page: 1, 2  Next
Post06-07-2021, 6:27    Subject: Vehicle Diagnostics Protection (VDP) Quote
Does anyone have experience with SFD (Vehicle Diagnostic Protection) in the current models of Audi, Seat, Skoda, and VW?
Recently, a customer wanted to have a brand new Audi S3 programmed, but unfortunately, the attempt failed.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber and Ste.Bo likes this.
Post06-07-2021, 20:13    Subject: Vehicle Diagnostics Protection (VDP) Quote
Good evening, Rainer,
Adjustments are possible. Conditional coding only.
For vehicles equipped with SFD, the hood must be open and the parking brake must be engaged.
Here, you could ask the customer again if they have made sure of something. Of course, it also depends on which control unit he wanted to connect it to.
17, 5F, 19, and 09 are definitely secured. I'm not sure about the engine control unit. There were some changes or modifications there. EU regulations.
Maybe he'll get lucky.
Otherwise, I was able to determine that after clearing the SFD (Subaru Fault Data), it is possible to continue working with VCDS as normal.
Michael.
Dagomanu
Karma: +55 / -0   Thank you, like it!
Post07-07-2021, 22:08    Subject: Vehicle Diagnostics Protection (VDP) Quote
Currently, certain adjustments can still be modified, but this will become increasingly limited in the future.
For official workshops (including independent ones), VW offers a cost-based online access to unlock the SFD (Software Feature Definer) function.
After activation, access is also possible via, for example. VCDS is possible.
After a certain period of time, or when using the original tester with the diagnostic output, the control units will be locked again.
Best regards, Dago.
Post29-07-2021, 8:58    Subject: Vehicle Diagnostics Protection (VDP) Quote
Vehicle Diagnostics Protection (VDP), Diagnostic Filters, Firewall
Dagomanu
dieselschrauber likes this.
Post29-07-2021, 9:35    Subject: Vehicle Diagnostics Protection (VDP) Quote
Does this also work for individuals, or only for companies?
Best regards, Dago.
Post29-07-2021, 20:00    Subject: Vehicle Diagnostics Protection (VDP) Quote
Best regards, Dago
It depends on the country. In Switzerland and Germany, I believe this is only applicable to companies (workshops).
Ich_Can_nix
Post29-07-2021, 22:54    Subject: Vehicle Diagnostics Protection (VDP) Quote
Hello everyone,
Currently, an offline token is required to disable the SFD in VCDS. This can be generated via the access point in the dealer portal.
The requirements for accessing the merchant portal are the same as those for the GeKo system. In addition, it is planned that each technician will be assigned a unique identifier.
Ultimately, it is possible to determine which technician made which modification.
Michael.
Hami likes this.
Post23-12-2022, 21:23    Subject: Vehicle Diagnostics Protection (VDP) Quote
There's something new coming soon regarding SFD, and the possibilities for independent workshops will become simpler. icon_idea.gif
chli1976
Karma: +185 / -0   Thank you, like it!
Post25-12-2022, 11:33    Subject: Vehicle Diagnostics Protection (VDP) Quote
dieselschrauber wrote:
There will soon be something new regarding SFD, and the possibilities for independent workshops will become simpler. icon_idea.gif
Okay, thanks, and please keep us updated.
VCDS
autoteilegarms
Post27-12-2023, 14:59    Subject: Vehicle Diagnostics Protection (VDP) Quote
Hello everyone,
Are there any new findings regarding SFD?
I have a 2020 Caddy with SFD, but I haven't been able to...
To activate the EPB (Electronic Parking Brake) overlay mode to switch between BBS (Brake Bleed System) and BS (Brake System)?
Reading the token via SFD in VCDS and then entering it to unlock the SFD in the control unit results in an "invalid token" error?
Is there another way?
Best regards.
Heiko.
Herbert likes this.
Post27-12-2023, 21:21    Subject: Vehicle Diagnostics Protection (VDP) Quote
That's not how it works.
Using the unlock request structure from VCDS, a token must be generated by VAG.
See:
VAG wrote:
https://erwin.volkswagen.de/erwin/downloadStaticFile/volkswagen/files/diagnostic/DE_SFD-Anleitung_fuer_UMB.pdf
Ross-Tech is working on a way to make this process more convenient.
Herbert likes this.
Post13-03-2025, 8:29    Subject: Vehicle Diagnostics Protection (VDP) Quote
Ross-Tech plans to provide owners of the HEX-V2 and HEX-NET devices, starting from a certain production year, with a limited-time SFD credit that they can use to generate corresponding tokens.
This would enable service work on the corresponding models.
Ross-Tech is working with VAG on an implementation. However, the challenges, which are not only technical, seem to be significant, and everyone working on a corresponding solution for diagnostic tools is grappling with them.
News related to this topic will be posted here.
Post15-03-2025, 0:44    Subject: Vehicle Diagnostics Protection (VDP) Quote
Distinction between SFD and SFD2:
SFD: Enables restricted access to control units using a release token (via VCDS).
In your car's scan, modules such as 15 (Airbags) and 46 (Central Conv.) display the SFD label, but not SFD2.
The SFD button appears in VCDS, and the protocol is UDS (not UDS-R).
SFD2 (enhanced security level):
Blocks all access (except for the gateway) with VCDS versions prior to 25.3 (currently only available in English).
The latest version of VCDS (25.3 or higher) requires "Restricted Mode" (UDS-R) to even perform a basic scan.
Attention, an SFD code is usually valid for 90 minutes.
yaya
Post18-02-2026, 16:08    Subject: Vehicle Diagnostics Protection (VDP) Quote
Code:
Adresse 03: Bremsenelektronik (J104) Labeldatei: 5WA-614-517-V1.clb
Teilenummer SW: 5WA 614 517 CF HW: 5WA 614 517 N
Bauteil: ESC H13 0135
Seriennummer: 92483000028622 Datenstand-Nummer: V03935404AQ 0001 CVN: BAE3684C
Codierung: B6046D9856246A6E527F6C0236CA81814BD208554AC8E70821BCB631018FF100001C38
ASAM Datensatz: EV_Brake1ESCEPBMQB37W 013058
ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
VCID: 0E445BxxxxxF52FA0D6-805A SFD <---
...according to plans by Ross-Tech, owners of the unlimited HEX-V2 and HEX-NET starting from a certain production year will receive a time-limited SFD credit, with which they can generate corresponding tokens...
That sounds good - I'm very excited to see what the future holds here. How do we solve this by then?
"I'm planning to have my braking system overhauled soon - and I'm seeing SFD in the log."
What other solutions are currently available if you don't have access to Erwin? Can a 1-hour access period be created for SFD?
ruler
Post02-04-2026, 17:59    Subject: Vehicle Diagnostics Protection (VDP) Quote
Best regards, Rainer
Are there any updates yet?
Best regards, Thomas.
Ich_Can_nix
Post08-04-2026, 23:34    Subject: Vehicle Diagnostics Protection (VDP) Quote
OEMs (Original Equipment Manufacturers) don't just want to get rid of private users; they also make it difficult for independent workshops.
I'm sharing an email I received.
The company is looking for a highly motivated and experienced software engineer to join our team. The ideal candidate will have a strong background in Java and experience with cloud technologies. We offer a competitive salary and benefits package.
Dear Sir or Madam,
To access the information needed for repairs online, independent market participants must apply for a FAZIT/GeKo authorization. Since April 1, 2024, this application process has no longer been handled by market societies/importers, but rather by national conformity assessment bodies.
"So far, all GeKo permissions that were granted before the introduction of the SERMI process on April 1, 2024, have remained valid. This will change on March 31, 2026. To comply with EU security standards, it will be mandatory from April 1, 2026, that you link your GRP user account with your valid SERMI certificate." All users with extended diagnostic privileges whose GRP user account is not linked to a valid SERMI certificate as of April 1, 2026, will have their FAZIT/GeKo privileges revoked starting April 1, 2026.
(If you have already linked your GRP user account with your SERMI certificate, you will not be affected by the aforementioned change.)
Even without FAZIT/GeKo authorization, you will be able to perform SFD unlocks and SVM functions. Safety-related work is only possible again once you have linked your GRP user account with your valid SERMI certificate.
How do I link my GRP user account with my SERMI certificate?
To activate the GeKo rights, you must start the "SERMI" application in the GRP system. You can generate a QR code there and use it to link to the certificate that was issued to you by one of our services.
The certificate was issued by an accredited certification body (https://www.vehiclesermi.eu/req.html#req). You can find a corresponding click-through guide in the attachments to this email. Please also refer to the procedures described in "Hinweise zum Diebstahlschutz und Beantragung einer FAZIT/ GeKo Berechtigung" <Volkswagen> for further information.
Please note that the connection established to the SERMI certificate is only valid for 60 days. Therefore, please remember to renew the certificate before the expiration date to prevent the revocation of your GeKo rights (to do so, simply follow the process described in...). Please review the SERMI click-through instructions again.
------------------End of text.----------------
For SFD 2, real-name verification and the Google Authenticator are required. I'm not sure how far you can get without an entry in the trade register or with a valid business license. The registration process alone is extremely lengthy, which already reflects a certain unwillingness to cooperate.
I can't imagine that things will be reversed or made easier. The fees for the Serma certification and for unlocking the gateways, as well as the OEM fees, are not insignificant. The fees are so high that it's hardly worth it for private users.
In future vehicles, the error memory will be located in the backend and will no longer be stored in the vehicle itself.
Michael.
No new posts Vehicle Diagnostics Protection: Firewall & Filters Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tachometer Manipulation: Protection & Prevention Transmission, Chassis, Body & Interior
No new posts Schutz vor Korrosion der Auspuffanlage? Transmission, Chassis, Body & Interior
No new posts Principle: Using bitumen or wax as a bottom protection Transmission, Chassis, Body & Interior
No new posts Vehicle measurement Transmission, Chassis, Body & Interior
