Ansteuerdauer + Kalibrierdrücke, euere Werte sind gefragt | Posts 48+
Go to page: Previous  1, 2, 3, 4
Karma: +1339 / -0   Thank you, like it!
dieselschrauber, Turbinchen and charmillo likes this.
Post15-09-2023, 19:24    Subject: Quote
A4 8K, CJCD engine (150 hp), currently at 180,000 km.
Injector 1:
- Common rail pressure calibration point: -5.14 µs.
- Common rail pressure calibration point: 2 -4.80 µs.
- Common rail pressure calibration point: 3 -7.10 µs.
Injector 2:
- Common rail pressure calibration point: -14.10 µs.
- Common rail pressure calibration point: -3.65 µs.
- Common rail pressure calibration point: -1.10 µs.
Injector 3:
- Common rail pressure calibration point: -16.35 µs
- Common rail pressure calibration point: -2.00 µs.
- Common rail pressure calibration point: 3 -8.35 µs.
Injector 4:
- Common rail pressure calibration point 1: 12.25 µs
- Common rail pressure calibration point: -18.85 µs.
- Common rail pressure calibration point: -16.30 µs.
Comparison values are available in my posts from August 2016 (48,000 km) and January 2020 (115,000 km). Some significantly negative values have decreased, and injector 4 is moving towards positive values with calibration point 1. Otherwise, no anomalies detected.
Translated on 04-08-2026, 11:55.
charmillo
2005 Audi A6 Avant
dieselschrauber likes this.
Post10-12-2023, 12:30    Subject: Quote
A6 Avant 4F from 2005, with a 225 hp engine, mileage: 253,000 km.
Injector 1 / MWB 72:
- Set calibration point 1 to 20.0 ms.
- Trigger Calibration Point 2: 16.0 ms
- Select calibration point: 3, duration: 2.0 ms.
Injector 2 / MWB 73:
- Select calibration point 1: 22.0 ms
- Select calibration point 2: 32.0 ms
- Select calibration point 3: 10.0 ms
Injector 3 / MWB 74:
- Select calibration point 1: 18.0 ms
- Trigger Calibration Point 2: 22.0 ms
- Select calibration point: 3, value: 12.0 ms.
Injector 4 / MWB 75:
- Select calibration point 1: 32.0 ms
- Trigger Calibration Point 2: 32.0 ms
- Trigger Calibration Point 3: 18.0 ms
Injector 5 / MWB 76:
- Trigger Calibration Point 1: 36.0 ms
- Select calibration point 3: 14.0 ms
Injector 6 / MWB 77:
- Select calibration point 1: 20.0 ms
The A6 seems to have quite a bit of carbon buildup, but it's not showing any obvious symptoms. I've owned the car for several years and regularly monitor its values. I've tried using additives at times, but they haven't made much of a difference...
It would be great if I could get feedback on the values and development process, if possible.
 File size:  143.53 KB
 Viewed:  1494 times
Translated on 04-08-2026, 12:01.
Stefan-5E5
2013 Skoda Octavia
Post19-01-2024, 14:11    Subject: Actuation Time & Calibration Pressure Explained Quote
Stefan-5E5 wrote:
Hello everyone,
Here are the details for my Octavia 5E5 4x4 CKFC: 191,000 km.
Rail pressure calibration times 1/2/3 in µs.
Cylinder 1: -23.6 / -28.4 / -24.0
Cylinder 2: -0.8 / -22.0 / -21.6
Cylinder 3: -23.2 / -26.8 / -20.8
Cylinder 4: 20.0 / -22.4 / -20.4
Stefan
Update with current values:
Mileage: 249,600 km
Cylinder 1: -21.2 / -27.6 / -24.8
Cylinder 2: -4.8 / -19.2 / -22.8
Cylinder 3: -23.2 / -28.0 / -23.6
Cylinder 4: 11.6 / -20.8 / -18.4
Skoda Oktavia 3, 4x4, CKFC, Serie 150Ps/320Nm, Chip ca. 180PS/400Nm.
Translated on 04-08-2026, 12:06.
lfb
Post20-07-2025, 20:30    Subject: Quote
Engine: CFHF, 2.0 CR-TDI.
Power: 81 kW, Torque: 280 Nm.
Mileage: 187,000 km.
IDE01387 Injector 1: Rail pressure calibration point -28.50 µs.
IDE01388 Injector 1: rail pressure calibration point 2 -7.05 µs
IDE01389 Injector 1: Rail pressure calibration point 3 -6.40 µs.
IDE01390 Injector 2: rail pressure calibration point -26.80 µs.
IDE01391 Injector 2: rail pressure calibration point -16.10 µs.
IDE01392 Injector 2: Rail pressure calibration point 3 -4.20 µs
IDE01393 Injector 3: rail pressure calibration point -27.20 µs.
IDE01394 Injector 3: rail pressure calibration point 2 -25.60 µs
IDE01395 Injector 3: rail pressure calibration point -20.20 µs.
IDE01396 Injector 4: rail pressure calibration point -21.60 µs.
IDE01397 Injector 4: rail pressure calibration point -21.55 µs.
IDE01398 Injector 4: rail pressure calibration point -19.75 µs
Translated on 04-08-2026, 12:10.
Stefan-5E5
2013 Skoda Octavia
Post23-12-2025, 12:23    Subject: Actuation Time & Calibration Pressure Explained Quote
Stefan-5E5 wrote:
Hello everyone,
Here are the values for my Octavia 5E5 4x4 CKFC.
Series 150 hp / 320 Nm, chip tuning to 181 hp / 398 Nm, 191,000 km mileage. Experiences occasional slight jerking in the partial load range below 1500 rpm. Unfortunately, mostly used for short trips up to 15 km.
Currently noticeable: the injector correction value for cylinder 4 is unusually high during idle and partial load conditions.
This one ranges from 0.57mg to 0.73mg, while the others range from -0.1mg to -0.3mg.
Stefan
Here are my latest compiled data for various running distances.
KM: 191,000 230,000 244,000 249,400 249,600 249,890 250,350 252,039 299,500
Zyl1-1 -23.6 -18.0 -28.0 -20.4 -21.2 -24.0 -21.2 -15.2 -8.0
Zyl2-1 -0.8 17.2 0.4 -2.0 -4.8 12.0 7.6 6.4 10.0
Zyl3-1 -23.2 -16.8 -29.6 -23.6 -23.2 -22.8 -20.4 -17.2 -14.8
Zyl4-1 20.0 21.2 26.8 22.0 11.6 22.8 24.8 31.6 25.2
Zyl1-2 -28.4 -27.2 -27.6 -27.6 -27.6 -30.4 -25.2 -24.4 -26.0
Zyl2-2 -22.0 -17.6 -21.6 -19.6 -19.2 -19.6 -18.0 -18.4 -19.6
Zyl3-2 -26.8 -25.2 -29.2 -28.0 -28.0 -30.4 -26.0 -27.2 -28.0
Zyl4-2 -22.4 -16.8 -18.0 -20.8 -20.8 -16.8 -17.6 -17.6 -20.4
Zyl1-3: -24.0, -20.4, -23.6, -24.8, -24.8, -25.6, -22.8, -23.2, -24.4
Zyl2-3 -21.6 -18.0 -21.6 -22.8 -22.8 -20.4 16.4 -21.2 -20.0
Zyl3-3 -20.8 -19.6 -23.2 -23.6 -23.6 -25.6 -22.8 -24.4 -25.2
Zyl4-3 -20.4 -16.0 -16.8 -18.0 -18.4 -18.4 -13.6 -17.6 -18.8
Note: Cylinder 2, calibration point 2 at 250,350 km is most likely a sign error, but I can no longer find the original data for it.
Translated on 04-08-2026, 12:18.
No new posts Important: Ash content and mileage - your input is needed Diesel Engine Technology
No new posts Chiptuning: Tuning Time & Calibration Pressure Impact Diesel Engine Technology
This topic is locked, you cannot edit or reply. Fuel Injectors: Flow Rate & Duration Data Needed Diesel Engine Technology
No new posts Golf V TDI Towing: Experiences & Tips Needed! Diesel Engine Technology
