Audi 80 B3 Turbo Diesel Tuning: How-To Guide
turbo D
Post14-11-2003, 16:36    Subject: Audi 80 B3 Turbo Diesel Tuning: How-To Guide Quote
Good day.
I would like to know how to tune the old turbodiesel engine from an Audi 80 B3 with 59 kW/80 PS. Is there much to gain with just a chip? I heard that you can modify something on the turbo. What exactly? And how many horsepower would that add?
Thank you in advance.
Chris.
Translated on 29-08-2026, 6:10.
Post14-11-2003, 16:47    Subject: Audi 80 B3 Turbo Diesel Tuning: How-to Guide Quote
turbo D wrote:
I would like to know how to tune the old turbodiesel engine from the Audi 80 B3 with 59kW/80PS. Is there not much to gain with a chip, or?
Hi Chris,
As far as I know, no chip is used in the engine; at most, potato chips are used as a snack during the mechanical modification of the fuel injection system (a different boost pressure control cone for the pump... icon_question.gif).
But I once heard that you can modify something on the turbo. What exactly? And how many horsepower would that add?
Probably just a simple pressure increase, maybe just twisting the wastegate rod... However, I don't know exactly how it's done on your turbocharger, so I'll leave the detailed descriptions to the drivers of similar engines.
Translated on 29-08-2026, 6:12.
michaB4
Post14-11-2003, 17:05    Subject: Audi 80 B3 Turbo Diesel Tuning: How-To Guide Quote
You can find some really good tips at www.golf3td.tk. However, if it's the 1.6 TD engine with 80 horsepower, it probably already has a low-pressure turbo installed. Therefore, you likely won't achieve much improvement.
Translated on 29-08-2026, 6:13.
Uli S.
Post14-11-2003, 18:33    Subject: Audi 80 B3 Turbo Diesel Tuning: How-to Guide Quote
turbo D wrote:
I would like to know how to tune the old turbodiesel engine from the Audi 80 B3 with 59kW/80PS. Is there not much to gain with a chip, or? But I once heard that you can do something to the turbo. What exactly? And how many horsepower would that bring?
Micha has already given you the correct link. These engines practically scream for tuning. With a few modifications, you can easily achieve 110 horsepower, and the engine can handle that consistently if you're not constantly driving at high speeds on the highway. With more extensive modifications and compromises in lifespan, you can achieve even more (140...). However, you should expect potential damage to the drivetrain icon_rolleyes.gif (drive shafts, transmission). My SB engine in a Golf 2 has 460,000 km on it, uses about 1.5 liters of oil every 7,500 km, and runs like a charm. I've been running at 110 horsepower for 550,000 km, but the transmission gave up. Because it was already too short, I've now installed one from an AFN.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 29-08-2026, 6:15.
No new posts Calix Motor Heater Installation Guide Troubleshooting & Guides
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Wer hat schon mal einen 2.4l-DC-Wirbelkammer-Diesel getunt? Diesel Engine Technology
No new posts Audi TT 8N: LLK for ARL Engine Conversion Diesel Engine Technology
No new posts Audi - Diesel mit CR ?? Diesel Engine Technology
No new posts Audi 2,5 TDI oder BMW 525 Diesel? Diesel Engine Technology
