Long Coding Helper needed - Climate/Heating module (E87)
blacks2
dieselschrauber likes this.
Post04-01-2024, 17:02    Subject: Long Coding Helper needed - Climate/Heating module (E87) Quote
"Good day, I would appreciate it if there was a long coding helper available for the following control unit."
Audi A5 2018 Climate Control - Address 08: Climate/Heating Control (E87) Label file: * Bypass failed!
Thursday, January 4, 2024, 12:57:52:04328
VCDS Version: RKS 23.3.1
Address 08: Climate Control/Heating Unit.
Control unit part number: 8W0 820 043 T.
Component and/or version: Climate Zone 3 H55 0210.
Encoding: 140948095544400D02000100080000000000000000000000000000000
Operating number: WSC 06335
VCID: 448CC98ECF8B37B3AF-8010
Enhanced Identification / CONCLUSION
Identification: BHB-001.
Date: 2017-11-03
Manufacturer part number: 0216
Test item number: 0441.
Flash Status
Programming attempts (application): 1/0/0/0/0
Flash Date: 2003-11-17
Flash Tool Number (Data): 00000 000 00000
Miscellaneous.
Hardware number: 8W0 820 043 T
System abbreviation: E87.
Equipment/PR code: 000000000000000000000000
Data version number: -----------
Data version: ----
ASAM Dataset: EV_AirCondiBHTCAU491
ASAM Dataset Revision: 001013
VCDS Info:
Label file: Route deviation failed!
ROD: EV_AirCondiBHTCAU491.rod
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein perfekter Tag für einen Spaziergang im Park."
Scan:
Thursday, January 4, 2024, 1:13:46:04328
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 23.3.1.0
Data as of: 20231010 DS346.2
Vehicle Identification Number: WAUZZZF56xxxxxxxx License plate:
Vehicle type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 18 19 29 39 42 44 46 52 5F 69 6C 6D
81 82 A5 AC BB BC CA D6 D7
Vehicle Identification Number: WAUZZZF56JA060233 Mileage: 94983 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
29-Light controller, left side -- Status: INTERFACE HARDWARE NOT COMPATIBLE.
39-Light control, right side -- Status: INTERFACE HARDWARE NOT COMPATIBLE.
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric. Front passenger seat. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
69 followers -- Status: OK 0000
6C Reverse Camera -- Status: Error 0010.
Rear hatch (6D) -- Status: OK 0000
81-Selector lever -- Status: OK 0000
82-Head-Up Display (HUD) -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: OK 0000
AC reducing agent dosage. -- Status: OK 0000
Rear left door electronics -- Status: OK 0000.
Rear right-side body control module (BCM) -- Status: OK 0000.
CA sunroof electronics -- Status: OK 0000
D6-light control, left side, 2 -- Status: INTERFACE HARDWARE NOT COMPATIBLE.
D7-light control, right side, 2 -- Status: INTERFACE HARDWARE NOT COMPATIBLE.
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-DCPC)
Label file: None
Part number SW: 8W0 907 401 G, HW: 059 907 309 L.
Component: 3.0L V6 TDI, part number H25 0004.
Revision: CAH25--- CVN: F68A85A171A47A97B866C2ADB866C2ADD6C3ECFE
Encoding: 1A2A401A0536050334080000000000000000000000000000
Operating number: WSC 06314 790 00001
ASAM Dataset: EV_ECM30TDI0118W0907401G 001004
ROD: EV_ECM30TDI0118W0907401G.rod
VCID: 3B7EB272B275484BDE-806E
VINID: 9D196AAAA58519A4401800830CE0649593
No error codes found.
Readiness: 0 0 0 0 1
Address 02: Transmission (J217) Label file:| DRV\0BK-927-156.clb
Part number SW: 8W0 927 158 H, HW: 0D5 927 156 H.
Part number: 0D5 30TDIRdW H05 1001.
Revision: --H05--- CVN: 394BC56F
Encoding: 100000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU49.rod
VCID: 4796DE82FEBD1CAB4A-8012
Address 03: Brake Electronics (J104)
Label file: DRV\8W0-907-379-PLU-V1.clb
Part number SW: 8W0 907 379 K, HW: 8W0 907 379 J.
Component: ESP9 Plus H10 0766
Data version number: 8W2909504D 0008 CVN: 18E61C2C
Encoding: 1CAA309A30A80A9651A0489400805292E4A592380C0C508A12004A4927A549
Operating number: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 4D9AECAA1CC1F6FB70-8018
Address 08: Climate Control/Heating Module (E87) Label file: * Bypass failure!
Part number SW: 8W0 820 043 T, Hardware number: 8W0 820 043 T.
Component: Climate Zone 3, H55 0210.
Operating number: WSC 06335 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
Control unit for the fresh air blower (front).
Subsystem 1 - Part number SW: 4M1 820 021 A, HW: 4M1 820 021 A.
Component: J126 FLuftV H08 0003
Serial number: 00000000000001810687
Humidity sensor: external.
Subsystem 2 - Part number SW: 4H0 907 658 A, HW: 4H0 907 658 A.
Component: AQ_Hum_Sensor H02 0007
Serial number: 1A2016D800PAG0MUFU02
Rear climate control panel:
Subsystem 3 - Part number SW: 8W0 919 158 HW: 8W0 919 158
Part: E265 Kli Fond H40 0080
Address 09: Central Electronics (J519)
Label file: * Diversion failed!
Part number SW: 8W0 907 063 CE, HW: 8W0 907 063 BE.
Component: BCM1 MLBevo H13 0267.
Data version number: 8W2909514E 0034
Encoding: 07501143C13900CD050D511818BD80B9100B3108000000000000000000001C810A450202001204
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 0004059E9B13EB93CB-8054
Wiper motor control unit:
Subsystem 1 - Part number SW: 8W6 955 119 HW: 8W6 955 119 Label file: DRV\1KX-955-119.CLB
Part number: 494 LL 060917 036 0471.
Serial number: 00000001709010300696.
Encoding: 5FC7F7
Rain and light sensor:
Subsystem 2 - Part number SW: 81A 955 555 A, HW: 81A 955 555.
Part number: G397_RLFSS H06 0002.
Serial number: 20856695X81A955555A0.
Encoding: 02005D
Light switch:
Subsystem 3 - Part number SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 26 06 2017 01000574
Automatic-dimming rearview mirror:
Subsystem 4 - Part number SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Interior Mirror, Part Number: H09 0002.
Serial number: GX1CE130081723310995
Encoding: 010000
Interior light module:
Subsystem 5 - Part number SW: 8W0 947 135 CN HW: 8W0 947 135
Part: J528-Roof Tile H14 0130
Serial number: B00557939
Control unit for driving and comfort functions:
Subsystem 6 - Part number SW: 8W0 925 301 AT HW: 8W0 925 301 AT
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000073913004
Encoding: 000000
Address 15: Airbag (J234) Label file:| DRV\8W0-959-655.clb
Part number SW: 8W0 959 655 F, HW: 8W0 959 655 F.
Component: Airbag 10.44 H03 0107
Serial number: 003UP009SRYR Data version number: 8W2909602AC 0010
Encoding: AACCF0C00C800000585000F3D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4C9CE1AEE7DBFFF367-8018
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: ----------- HW: 442 062 610 17
Part: SideSensor_Df 1E2 0887
Serial number: 3577Y00C3258C230720Q
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side:
Subsystem 2 - Part number: SW: ----------- HW: 442 062 110 17
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00B728A7A7301D7
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side):
Subsystem 3 - Part number: SW: ----------- HW: 442 0B1 810 17
Part: SideSensor_Dr 1C7 0148
Serial number: 3517700B127F01A173FA
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side:
Subsystem 4 - Part number: SW: ----------- HW: 442 0B1 910 17
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700B727F01A5F2FS
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 442 0C1 107 17
Part: FrontSensor_D, 1C5 014A.
Serial number: 3557500B12665765720/
Encoding: 2D2D2D
Crash sensor for front airbag, passenger side:
Subsystem 6 - Part number SW: ----------- HW: 442 0C1 107 17
Component: FrontSensor_P, part number 1C5 014A.
Serial number: 3567500B326657657389.
Encoding: 2D2D2D
Crash sensor for pedestrian protection, center.
Subsystem 7 - Part number SW: ----------- HW: 442 0C1 107 17
Component: PedP_Sensor_C, Part Number: 1C5 014A.
Serial number: 2307500C72711FF3B2AH
Encoding: 2D2D2D
Crash sensor for pedestrian protection, driver's side, part 2:
Subsystem 8 - Part number: SW: ----------- HW: 442 431 410 17
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00BF24F3711219D
Encoding: 2D2D2D
Crash sensor for pedestrian protection, passenger side, 2.
Subsystem 9 - Part number SW: ----------- HW: 442 431 410 17
Component: PedPSensor_P2 256 0887
Serial number: I0N9M009D25B69E274B-
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527)
Label file: 4M0-907-129.clb
Part number SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Steering module H11 0009.
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76E86346C9D7D523E1-8022
Address 17: Terminal block (J285) Label file: * None-SRI2
Part number SW: 8W6 920 771 A, Hardware number: 8W6 920 771 A.
Component: TDIeRDW H09 0629
Encoding: 05A441C6288000080023E9601000600000000000
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU49.rod
VCID: 4084C59EDB932B938B-8014
Address 18: Auxiliary heater (J364)
Label file: * None
Part number SW: 4M0 265 105 E, Hardware number: 4M0 265 105 E.
Component: HSG H11 0090
Data status number: 8W2909858C 0009.
Encoding: 0D0F01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736_AU49.rod
VCID: 2952783A48E9CADBBC-807C
Address 19: Diagnostic interface (J533)
Label file: * None
Part number SW: 8W5 907 468 F, HW: 8W5 907 468 E.
Component: Gateway H42 0123
Revision: 7A000001 Serial Number: 0187A557717A27 Data Version Number: 8W2909515D 0039
Encoding: 03010001000006407F07000000590012C8180007100000000175078F10000000
GVL: 01503C0808040000C08C08000006C80010080000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 8W0 951 523 F HW: 8W0 951 523 F
Part number: J453 MFL H04 0002.
Serial number: 20171019133926 21728
Battery monitoring control unit:
Subsystem 2 - Part number SW: 8S0 915 181 C HW: 8S0 915 181 C
Part: J367-BDM Hella H10 9070
Serial number: 3996805604
Address 29: Left-side lighting control.
Interface hardware is not compatible.
Please purchase a current Ross-Tech diagnostic interface.
Address 39: Right-side lighting control.
Address 42: Door electronics. Driver (J386) Label file: * None
Part number SW: 8W0 959 593 H, HW: 8W0 959 593 F.
Part number: TSG FS 005 0125.
Serial number: 0000284105657. Data version number: 8W2909872B 0024.
Encoding: 001D4B625000000000011480
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
VCID: 4FA6F6A216CDC4EB02-801A
Address 44: Steering Assist (J500)
Label file: * None
Part number SW: 8W0 909 144 H, HW: 8W0 909 144 B.
Component: EPS_MLBEVO_ZF H08 0410
Data record number: 8W2909852P 0031.
Encoding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
FILE: EV_EPSZFAU49X_003.rod
VCID: 4280CF96D59F39839D-8016
Address 46: Comfort System.
unavailable
Address 52: Door opener (or electric door release). Passenger seat. (J387) Label file: * None.
Part number SW: 8W0 959 592 H, HW: 8W0 959 592 F.
Part number: TSG BFS 005 0125.
Serial number: 0000282130084. Data version number: 8W2909873B 0024.
Encoding: 001D4B225C00000000011480
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 4E98EBA611C7CDE309-801A
Address 5F: Information selection. I (J794) Label file: * 8W0-035-MIB-HGH2.clb
Part number SW: 8W5 035 036 B, HW: 8W5 035 036.
Part number: MU-P-LN-EU 034 1177
Serial number: A795J0HB066007
Data version number: 8W2909545L 0035
Encoding: 01940301FF00000053110001000A00332F000E65017001009E
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 3776AE428E5D6C2B3A-8062
Data storage devices:
Subsystem 1 - Part number SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Serial number: --------------------
Display unit 1 for the multimedia system:
Subsystem 2 - Part number SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170.
Serial number: TPO00125091700820251
Control unit for multimedia system:
Subsystem 3 - Part number SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK125091700040459
Compact Disc Database:
Subsystem 4 - Part number SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 69: Trailer (J345) Label file:| DRV\5Q0-907-383.clb
Part number SW: 4M0 907 383 F, HW: 4M0 907 383 B.
Part: Trailer H27 0253
Revision: 9A001003 Serial Number: 0459200870 Data Status Number: 8W2909527A 0005
Encoding: 0110000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 356AA44A94519E3B28-8060
Address 6C: Rear-view camera (J772)
Label file: *Rerouting failed!*
Part number SW: 4M0 980 556 A, Hardware number: 4M0 980 556 A.
Component: RVC Compact H18 0250
Encoding: 0294000101002007000040
Operating number: WSC 12345 123 12345
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 336E9A529A25800B06-8066
"1 error found:"
10489856 - Basic configuration not performed.
B2010 00 [009] - -
[New feature!] Extended UDS error code information is only supported by current hardware generations.
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 5
Error frequency: 1
Lost Count: 83
Mileage: 94983 km
Date: 2024.01.04
Time: 13:07:09
passive
Address 6D: Rear door (J605) Label file8) DRV\5Q0-959-107.clb
Part number SW: 8W8 959 107 B. Hardware: 8W8 959 107.
Component: HDSG Module H13 0163
Revision: --------
Serial number: 31616072600000
Data status number: 8W2909541B 0004
Encoding: 0690
ASAM Dataset: EV_DeckLidCONTIAU736 001015
ROD: EV_DeckLidCONTIAU736_AU37.rod
VCID: 4894DDBEF3A313D343-801C
Address 81: Selector lever (J587) Label file: 4MX-713-041-81.clb
Part number SW: 8W1 713 041 F, HW: 4M1 713 041 F.
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 17102844626975
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSM_selection_ZFAU736_AU49.rod
VCID: 3668A3468957952321-8062
Address 82: Head-Up Display (HUD) (J898) Label file: * None
Part number SW: 8W6 919 617 HW: 8W6 919 617
Component: Head-Up Display H09 1640.
Encoding: 2B01C0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 06081386B937C5A3F1-8052
Address A5: Front/Forefield camera (R242)
Part number SW: 8W6 907 217 A, Hardware number: 8W6 907 217 A.
Part: BVS H16 0050
Data record number: 8W2909466C 0019.
Encoding: 0404090300000401022023A1850000FC10F0C020C280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address AC: Reducing agent dosing unit. (J880) Label file: 4M0-907-355.clb
Part number SW: 4M0 907 355 D, HW: 4M0 907 355 B.
Component: SCR Control Unit G3H04 0006
Data version number: 8W2909571D 0004
ASAM Dataset: EV_RDCMINERGAU736 005012
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 32609F56653F89030D-8066
Address BB: Rear left door electronics (J38http://shop.dieselschrauber.org/en) Label file: * None.
Part number SW: 8W0 959 595 H, HW: 8W0 959 595 F.
Part number: TSG HFS 005 0125.
Serial number: 0000285984918 Data version number: 8W2909897B 0021
Encoding: 000D49220000000000001080
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 51A2F0DA00F9D21B14-8004
Address BC: Rear right door electronics (J389)
Label file: * None
Part number: TSG HBFS 005 0125.
Serial number: 0000285984915. Data version number: 8W2909896B 0021.
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address CA: Sliding roof electronics.
unavailable
Address D6: Left-side lighting control.
Address D7: Right-side lighting control 2.
End----------------------------(Duration: 05:47)-----------------------------
Post04-01-2024, 17:45    Subject: Long Coding Helper needed - Climate/Heating module (E87) Quote
Thank you for the information!
Regarding
Status: INTERFACEHARDWARE NOT COMPATIBLE
I recommend:
https://shop.dieselschrauber.org/en/vcds-interface-upgrade-p-342.php
I will forward the data from your climate control device to Ross-Tech.
What would be worth trying: Testing the current English version of VCDS.
https://www.ross-tech.com/vcds/download/current.php
blacks2
Post04-01-2024, 17:58    Subject: Long Coding Helper needed - Climate/Heating module (E87) Quote
Hello, thank you for the help.
Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Address 08: Auto HVAC (E87) Labels: * Redir Fail!
I ordered the update from you last week (V2) icon_smile.gif.
Sure, here's the translation:
"VLG" is an abbreviation for "Very Large Language Model." It refers to a type of artificial intelligence (AI) model that is trained on a massive amount of text data and is capable of generating human-quality text. VLG models are used for a variety of tasks, including:
* **Text generation:** VLG models can be used to generate text for a variety of purposes, such as writing articles, creating marketing materials, and generating code.
* **Translation:** VLG models can be used to translate text from one language to another.
* **Question answering:** VLG models can be used to answer questions based on the information they have been trained on.
* **Summarization:** VLG models can be used to summarize large amounts of text.
* **Chatbots:** VLG models can be used to create chatbots that can have conversations with humans.
VLG models are still under development, but they have the potential to revolutionize the way we interact with computers and the world around us.
Post04-01-2024, 18:08    Subject: Long Coding Helper needed - Climate/Heating module (E87) Quote
Ross-Tech wrote:
I believe that this module supports experimental coding (note the asterisk next to the designation), but this would only apply to HEX-NET or HEX-V2, not to HEX+CAN for this customer, even if they are using an English version of VCDS.
Is there a specific coding change that this customer is trying to make?
blacks2
Post04-01-2024, 19:00    Subject: Long Coding Helper needed - Climate/Heating module (E87) Quote
Thank you - then I will wait for my V2 icon_smile.gif.
blacks2
Post25-01-2024, 17:12    Subject: Climate coding implemented - heated seats still not working Quote
With the HEX-V2, it was now possible to make up for the missing encodings.
Unfortunately, the buttons for the seat heating still don't light up when pressed, and the seat heating is not working. No further error messages.
Fuse for seat heater, fuse box C (black).
The front seat heater located under the footrest is working properly.
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Long Live III Oil for Golf 4 TDI ARL, year 2002? Diesel Engine Technology
No new posts Bosch EDC15 Wiring Diagram Needed On-Board Diagnostics (OBD)
No new posts Piston Retraction Tool: Do You Need It for VAG? Transmission, Chassis, Body & Interior
No new posts Russia Problems: Urgent Help Needed! Diesel Engine Technology
