Calibrating the intake manifold pressure sensor on a 1.4 TSI engine
harzer1
Post30-01-2024, 16:55    Subject: Calibrating the intake manifold pressure sensor on a 1.4 TSI engine Quote
Hello, I replaced the potentiometer for the intake manifold flaps on my Golf 5, 1.4 TSI, BLG engine.
ERWIN VW states that after the replacement, the learned values should be erased and the engine control unit should be reprogrammed.
Is this path available in VCDS as well?
Post30-01-2024, 18:05    Subject: Calibrating the intake manifold pressure sensor on a 1.4 TSI engine Quote
Autoscan is missing... I would say, based on my gut feeling, that the adaptation channels from the engine control unit should be checked.
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A6 Key Programming: Can it work with A8? On-Board Diagnostics (OBD)
No new posts Audi A8 4E: Program new keys On-Board Diagnostics (OBD)
No new posts ESP comparison > Poti and... HDK Sensors Diesel Engine Technology
No new posts MKB 1Z Error Codes: Slider Position Potentiometer - G99 Diesel Engine Technology
