Controlling pumps/nozzles: Short circuit to positive
maendy
Post01-02-2024, 10:31    Subject: Controlling pumps/nozzles: Short circuit to positive Quote
Car brand: VW
Car Model: PASSAT B6 Variant (3C5)
Year of construction: 02.2008
Motor code: BMP
Error code: Error: 005731 Control of valves, pumps/nozzle. P1663 - 000-
Short circuit detected - warning light illuminated.
Error: 005731 - Valve control for pumps/nozzle.
P1663 - 000: Short circuit to positive voltage - Warning light illuminated.
The error can be deleted, but it reappears with the next attempt to start.
The fuel injector wiring harness (original part) was replaced in the car about a year ago.
"The nozzles were also re-sealed."
We've re-checked the nozzles and the wiring harness (Okay).
Also, here's the translation:
"Also, I visually checked the wiring to the control unit and the fuses in the area."
"Checked the starter and didn't notice anything unusual..."
Since I didn't have an oscilloscope, I couldn't measure the outputs.
Translated on 07-07-2026, 4:36.
Post01-02-2024, 19:18    Subject: Controlling pumps/nozzles: Short circuit to positive Quote
I would start the tests by connecting only one PD element at a time and clearing the error memory after each attempt. Then you'll see where your mistake is and where it isn't.
Translated on 07-07-2026, 4:37.
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Short circuit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
No new posts Error 00532 - Power supply / Short circuit after positive... Diesel Engine Technology
No new posts Exhaust pressure sensor 1 (G450): Short circuit to positi... Diesel Engine Technology
No new posts Intake air temperature sensor (G72) - Short circuit to gr... On-Board Diagnostics (OBD)
